  • Replies 2k
konis/kings, seems to be all right but will see as time goes by how firm the konis stay, a mate has them on his r30 put them in about 9 months ago and hes saying there are getting soft, his is a daily driver, mines gone 60km since the ignition was wired up, i can say cornering is flat and fast!!
anyone seen the second last page of the latest HPI mag as there is the whole page to the DR30, small write up not to much info what they do say though is stay away from a dr30 for under 10,000 and be prepaired to pay up to 15,000. Also i emailed the bloke about the RS turbo booklet and he said its in japanese, but he did say that hes got a 20 foot container of dr30 parts and panels plus a couple of cars comming over in march so if there are things people are looking for then he may be to go!!
ah yes that SA GUY....sed he had a dr30 diff he would sell me for $1300....wtf.
on the dr30 front bar issue, got a qoute for one ..800$ landed from that jenesis place
1300 on a r200 diff i quess??, the front bar quote is that through rezz or jenesis itself?
I haven't actually pulled the diff apart to look yet. It open wheels and twins up then opens again so it ain't in the greatest condition. Probably just shimming or drive plates just guessing. I wanna change ratio's as well but that could be expensive.
sounds very much like my diff, under load it twins, but free spin it has one going one way and the other spins the other way?? was told the diff in a pintara has the perfect ratio for track and was a good swap?? thats what i was told!!
boof- pm'ed stu-r30 with the details and seems hes done deals with him?? may be ask stu-r30 what he thinks??
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
