Mate you should try getting a straight answer from our wankers at regency, depending on what time and who u speak to you will get a different answer both times...They have NO idea!!!   :bs!:
thats what i figured so i was checking to see if anyone has ever got a REAL answer and then passed at a later date
  • Replies 2k
Sorry Guys, As I am in NSW I can only give their regs, but as a thought, maybe speak to the guys at Jaustech or Japanese Motorsport.
As they are into modified cars, Jaustech in particular doe a few R30's, they might be more up to speed.
Good luck,
Dennis
I bought a GT30 turbo,turbosmart wastegate,s/hand mazda injectors,hybrid intercooler and Wolf ecu.Thats it.
Standard manifolds,head,cams,throttle body...all stock.It runs 18psi boost and BP98 fuel and is a rocket!
I cant wait to fit my Tomei 272 cams and put 25psi into it!
If thats all i have to do than im off to the wreckers to look for an fj20det, should of done it earlier.
What colour is your R30 Mike???  Its not Nissankings old R30 is it??  I've sen that thing getting round heaps lately, still looking tough as :)
nah i dont think it was, mine is the blue/silver color but at the moment it has alot of base coat on it as its almost ready for the resray...
hey guys, got an update. i put r31 shocks in the rear and new r30 ones in the front, and lowerd it on corbra's springs. not superlows just low. and well the front didnt even change at all hight. 10mm max!. even knowing these springs are rated to 20-30mm :P. and do i overcome the fact i only have 7cm of travel in my shocks.?
im confused
hey guys, got an update. i put r31 shocks in the rear and new r30 ones in the front, and lowerd it on corbra's springs. not superlows just low. and well the front didnt even change at all hight. 10mm max!. even knowing these springs are rated to 20-30mm :(. and do i overcome the fact i only have 7cm of travel in my shocks.?
im confused
Ive got the same trouble.I converted my R30 struts to a height adjustible coilover setup and found when i lowered it to where i wanted it i would lose all my shock travel.(so now its jacked up like a landcruiser).
But i went to the susp shop for advice and he said he will replace the top mount(thick rubber housing the bearing) with a thin metal plate(my understanding) that will allow me to lower it and keep the travel. :looney:
Hey!!! Didn't anybody read my earlier post on lowering, #351?????
Due to the lack of travel in the damper, to lower an R30 front and rear, it is necessary to use R31 Strut inserts because they have a 42mm shorter travel and R31 rear shocks have a 32mm shorter travel in the damper.
But if you use good springs, like I have 250 lb/in front & 200 lb/in rear the travel nearly is obliterated, the springs hardly move.
My Hr30 has JIC coilovers from Japan and are physically 50mm shorter than the corresponding front or rear strut / shock assembly and the fronts have camber tops on them.
Hey guys, i have an MR30 sedan, currently installing an RB20DET, looks like a nighmare to wire up, apparently the g/box mounts should bolt up... Its bolted in, but still not wired up.
I ve painted the car in 2pak, gold and put R33 disks and 4 piston calipers on front, std rear disks, adj. coilovers, fibreglass front bar, strut brace, nolathane bushes, series 1 dr30 tail lights, 16x8 watanabe's (no rubbing problems running 245/45/16), bolton 20mm spacers and a few other things. Im sure i'll run into some problems while hooking up the RB20 tho
pictures - http://www.pbase.com/crimmo
dr30turbo - if you get 2 front struts with your HR30 from paul, they will bolt in no worries, i bought the koni shocks brand new and the springs are heavy duty pedders, all came out of my car when i converted to big brakes and coilovers, they handle very well.
Hey, Crimmo about those konies... are they red or yellow? i got those off paul but like a day after paul gave them to me they leaked oil on the ground. i wasn't sure weather to put them in or not it seemed a bit dodgey. i don't know what to do i mean are they sealed or could i get more fluid for them or something.
Hey R30_Turbo, the leak is nothing to worry about, the koni insert slides into the strut case, and the koni insert itself is sealed and thats not what is leaking, all struts have a small amount of oil in the bottom of them to lubricate the shock absober insert, they are adjustable koni red's 'special' :)
Try to leave them sitting upright and they wont leak. The sleave that screws into the top may need tightening, by when they are in the car they never leak, unless you roll the car! :D
hey guys can u get aftermarket pulleys for FJ20ET's? the main crank pulley on mine i think is ok but the other 2 behind for alternator and a/c move up and down on the crank shaft heaps more than they should.
is there any like aftermarket pulleys of some sort you can get? or better to replace with originals? (ne1 got any spare? haha)
Hey Stu,
have you wired up your RB20 yet. I sat down last night and tried to figure out the RB25. and i came to a conclusion. i know nothing about EFI cars. for example what does an ECCS relay do. question is are you doing yours yourself or are you using a conversion shop. :Bang:
got it all wired up bar the rpm...
my dad knows whats goin on so hes helping me (read : doing most of it) to wire it up
what do u need to know about the 25 i may be of assistance....or hinderance.
what has everyone done in respect to cooler piping?? i mean if your using a f*ck off big frontmont then are u running the "cooler to TB" pipe over the radiator or under?
if u get what i mean? maybe not.
    • Did you pay with a credit card? I'd be putting a charge back through then finding a new sparky to sort it out.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
