  • Replies 2k
In the engine bay, next to the firewall??????
If you are above it looking over the o/s/f guard and it sits below the light relay on it's own, like at the bottom below 2 other relays, you don't need it unless your an AUTOMATIC (heaven forbid matthew) because it's the inhibitor relay, according to the manual.
But if you are looking at it from the n/s/f guard and it has some wires connected at the side of it, it is the horn relay.
Does this help?
You should have a manual, I got a spare that I got with my car if your interested. :ghost:
i have a manual for the mr30 which is an auto, the other thing is i have the fuse cover for it but its in japanese?? the english version for the mr30 states its an inhibitor relay for the auto mr30 thats why i had to ask as the 2door is and was a manual, in short what your saying is that its nothing to worry about?
i'm doing a trial and error to see why the lights and indicaters are not working, will be replacing the indicator stalk tommorrow as i think this is the problem!!
thanks anyway ghostrider!
If your using high power globes, you have probably burnt the contacts on the switch, or somebody has at some time.
I have, an extra loom that came with my original iron mask front cut, an extra loom just for the lights.
It draws power from the main circuit breakers, but has a 30 amp relay for each globe and the loom is about an inch thick.
But the globes I'm using are the latest & greatest from IPF in Japan. Mains 55 W input/ 145 output and high beam, 80W input/ 165 output, but still using the extra loom to be safe.
http://www.carsales.com.au/pls/carsales/!c...rch_distance=50
interesting......
found this r30 while looking for a Calibra on carsales.com
since when have skylines been 4cyl-i thought there were only 6cyl?
anyway check it out... :rolleyes:
nicko in my work i drive around in a yellow van with flashing lights on the roof that comes to help when your car breaks down.
In my work you quickly learn which cars are reliable and which are not.
My advice would be to not buy a Calibra,Astra,Vectra etc etc.
Ghostrider are those headlight globes the blue tinged ones you see on some late model beemers and such?The extra wiring/relays is a good idea with brighter globes.(watts divided by power(12v) gives your current draw).Most of the factory relays are not able to cope.
Do you have any pics of your 30 for all to see?
Regards Todd
Can anybody tell me What is the AFM in my mR30 and where is it, should i just take it out to get better proformance and what is the ECU. and how do i put a resitor in between the AFM and the ECU. Also would a RB30 coil do any good in a MR30
Thanks again josh
The AFM is located at the bottom of your airbox AND I would be very surprised if it went at all! without it.
The ECU is located in the passenger side inside kick panel and it is Engine Control Unit and without this, IT NO GO AT ALL.
Forget the resistor, you get suckered into buying the 20Kw performance pack on ebay????? They only work in temperate conditions, if like today, "a stinker, HOT HOT HOT. it won't do anything more than eat a sh#t load of fuel.
As for RB coil, don't know, ask an auto electrician, but if it's the bosch coil, can't see a problem, but difficult to use the EFI coil packs. :ghost:
Thanks again josh
looked a little harder for you about the msd coils, what you need to be asking about is the msd blaster coils as the other ones they are trying to sell you are a individual coil per cylinder and far to expensive!!
question - for the firing order on an rb20, how do i run the leads to the coil packs.
is it sparky one to coil one, s2 to coil 2 etc...
or is it sparky 1 to coil one, sparky 2 to coil 5, sparky 3 to coil 3???
assuming the firing order to be 1-5-3-6-2-4
if anyone understands what im rambling about
yeh and the resistor thing that you speak is as ghostrider said a slight waste.
my AFM was adjusted internally at the flap by Datrally in melb and they spent a long time doing it and many dyno runs till it was right not something you should really frig with especially when you don't even know where the AFM is on your car
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
