  • Replies 2k
Yeah, but people keep throwing up 200hp figures for the Paul Newman which is bs... if that has 200hp my fj20 must have 300hp lol
Careful Adam,
You might be accused of being blasfamous, after all, my Paul Newman has a lot more than 200. LOL
Adam,
I think they quick, just depends on the comparison.
My mates in Adelaide tell me there is a Paul Newman down there, that after caning it's ass off, it does 15's at the 1/4.
Hold that thought for a moment, 15.??? second 1/4 time and have some consideration for our own aussie muscle. The 5.7 litre Monaro only manages 17's for the 1/4, off the shelf.
Compared to that! the Paul Newman is pretty quick eh!!!
Sams IS the Adelaide Paul Newman, its standard apart from a turbo that is apparently a "triple hybrid", filter and exhaust. Its bloody clean though, and it sounds sweet, but its slow. Sam reckoned that my car was noticably faster when he went in it... which is when it had a huge boost leak. And now that mine doesnt have a leak, its much quicker
How many are there in Australia now? When Ivan was advertising his he said there was only three... his, Pauls (now Sams) and another one that was in either Sydney or Melbourne
I still doubt that the Newmans had 200hp standard, or even much more than 145.
Shit, my Charade GTti must have been a monster... stock except for the exhaust it ran a 16.7 (granny launched... just drove it normally (ie sloooowly) off the line) but at 85mph lol
BTW Sam lives in the house behind mine :D
i think you'll find that the ones ghostrider and i are talking of are not STANDARD and you are on the mark with your stock power figures give or take! :D
you might be able to answer a question though! were the paul neumans released in 2 or 4 door version as my mates is a 4 door and he seem to think they were only ever released in the 4 door version??
hey all...i just bought a r30 hatch for $200....im gunna stick the motor/box(5speed) into my 1.2litre 2wd hilux.......can the ecu be modded or do i have to buy an aftermarket computer? i want to put headers and a cam in it.....btw the motor and box are A1
oh....bummer...how far can u go with these motors before needing to change the ecu? im guessing head work and pipes is about it?
if anyone read the ZOOM engine review then according to them the ECU can be played with?? but i think the problen is finding someone that has bothered with these engines here in OZ.
the trouble with the vane airflow meters, well in my mates case was that they flip wide open under boost and go to 9:1 A/F ratio.
thats why you see so many pulsar Et's blowing chaff
i think from memory you can basically adjust idle, mid and high mixtures
took my car to work with me on saturday, i know the trouble i could have been in, 40k round trip, all and all she went like a dream, one miner problem, no indicators!! it was something i had to do and was not disapointed!!
Fun arent they :)
I drive mine the looooong way to uni, go up through and across the hills instead of just cutting across town.. only takes 5 minutes longer, and its a hell of a lot more fun :evil
the thing is with mine its unregistered and i'm running an rb20det so its fun and illegal!! :sadam:
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
