That DR is for sale.
Ben Ellis had it at the IDA drift day at Oran Park in Feb this year.
You have the best CAM maker in the country up there near you, Tighe Engineering, they made my n/a cams, brand new, just needed my stock cams for samples to cast the billet blank.
Cheers,
  • Replies 2k
do you mean as in ivan tighe?
Sure do!!!
He made our RB26/30DE hybrid cams.
The wildest duration, over 350 degrees each for the princely sum of $840.00 pair.
When searching around, HKS, Trust, Tomei etc were all that much & more EACH and could/would not supply bigger than 284's.
Cheers :ghost:
Sure do!!!
Cheers :ghost:
damn thats crazy!
i've driven a r31 gts-x with the nics red top and there was nothing there to make me smile in my eyes my rb30e goes harder, from memory the nics red top was only 20hp more than the l20et, to its defence though it was the very next 6cyl engine nissan produced after the l20et, silver top has 205hp at the fly same as the intercooled fj20, produces around 15 more Nm at 6500rpm and with around $2500 in mods should produce around 160rwkws, rb25 turbo and remap 180-200wrkw, vg30 turbo and remap of stock ECU 200-220rwkw...parts and upgrades are at your fingertips from a range of places!! my two cents...
Was it an auto GTS-X by chance? The NICS RB has 180hp if I recall rightly,and the L20et had 145hp? Auto kills the NICS,but 5spd isn't much better. You must have had a freaky RB30E if it went better than a manual RB20DET! I've owned both,and know what I'd prefer.Not that I particually like RB20DET's either........
once the turbo runs at full rpm (silver top makes full power at 6500 engine rpm)its not going to produce more power so the only way to go faster would be to change gear
Yes,I am aware of that :D I was commenting on their ability to rev more than 5k.
No thanks, Butchery is not my stock & trade.
I meant with the proper machinery, ie a lathe, hence its not butchery but a modification....if you arent into modification, why are you messing with adj cam gears?
no offence
A GTS2 RB30E is good for 145Kw at the fly.
Yes,I am aware of that ;) I was commenting on their ability to rev more than 5k.
i think it was just a sh%t example of a gts-x :D
Hey Guys!! Got my clutch and all that in now, she's sweet as!! Ran my water lines to my turbo, thats sweet as as well just need my hose clamps for the oil return line and the turbz is finished!! Then i need to find my panels :bs!: and its almost ready to go!!
As a quick question, what do u rekon a stock DR30 Fj20 exhaust manifold is worth selling for???
hmm my mate has a gts-x, its got a deep dark secret under the bonnet though!!!
silver top rb20det eccs, with nics finned red rocker covers!! highflow turbo, fmic, mines ecu
the bloody TPS has shat itself though.
that car does sound amazing even with a stock zorst, incredible spool noise. catches many unaware
meet a guy at the last massive skyline cruize here on the coast with a gts-x that had a rb25det under the bonnet.. now thats a kicker!!
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
