I got a stock one, but otherwise get it made.
Your sedan got rear discs with it's IRS???
All hatch's have rear discs and they're interchangeable with sedan. Just attach at cross member, but if you do this you will need the handbrake cables as they are different to the drum ones.
nah got me a dr30 rear end. disc, calipers, shafts, everything except diff
  • Replies 2k
r31 gts front shocks etc with discs and calipers
rear is dr shafts (i think) but an r200 open wheeler which has stood the test of time for at least a year of second gearies
Same spec, just different offset on hubs.
Is yours pre or post 83?
82
You would have a TOKIKO style master cylinder???
If yes, there is a 1 inch upgrade available, don't know what vehicle it comes off, but if you took your old 7/8 m/c to a brake shop, or you know exactly what it looks like, get them to order you one.
Our 84/5's can only go up to 15/16 unless we change all the bundy tubing.
im not sure. the cylinder seems to be holding up ok so far. what are the advantages of changing it?
makes sense. z31 discs are the same as dr30's?
Same spec 274 x 22 as your R31 GTS.
We have discussed this topic extensively on another thread.
I have DR front & rear, slotted rotors and EBC green pads up front & black rear.
They are a high temp KEVLAR compound low friction, excellent road set up. But I am going to upgrade my fronts to BNR32 GTR 296 x 32 with 4 spot Nissan alloy calliper, only because I have, potentially over 300Kw at the wheels.
Anyone know if cutting a MR30 hatch grille (the eggcrate one with the three slats) so that the eggcrate crap comes out, effictively makes it the same as the other three slat grilles?
And if a set of coilovers were made for a 180B, they should bolt up to a R30 since R30 stuff bolts up to Dattos?
when i did the engine swap the machanic put the r32 master cylinder on mine, never had a peddel feel so good! with the hr brake callipars on mine i had to go to bendix comp X pads as EBC dont make front pads for these callipars...
Jenesis is www.r30.co.jp but when you access it put it through Alta Vista translation or similar so you can sort of understand what there saying in descriptions.
BUT! don't get to excited, they won't trade with you DIRECT, it's a good site to explore, and a lot of their parts can be made here just from the pictures. It is a good referrence site as well, to see what they do with them in Japan.
If your interested in getting some bits from them, it might be a good idea to put it to open forum discussion and we try and jointly get an order together and then get in touch with a parts importer, like Nengun, one of SAU sponsors.
Only one problem I can see with your car...... far too many doors!
i'd put my hand up for a group order from jenesis as there are a few body parts i'd like from them, i could speck to the boys at option 1 as they have have containers comming over each month...
Already done that, I talk to Nathan & Paul at least once per week.
Yeah i would be interested as well in getting some stuff from jenisis...I know in one of the earlier pages on this mammoth post that there was talk bout it, but that kinda died in the ass i spose...I wouldn't mind some of that bracing for a start that would rock!! Depending on what we can get and for what sorta $$$ it will all cost of course though!!
Geez,you've gotta be on the ball to keep up with this thread!! :D
Talk to Whiteline and they will tell you both rear tower brace and floor braces aren't necessary' date=' but Jenesis makes, sells & uses them, so! someone aint up to speed.QUOTE']
I thought it was still a good idea,even with a rear tower brace,as the mid-section can get a bit "flexy" with no B pillars...
Also,I may be interested in a engine dampener brace from Jenesis,depending on price.Does anyone know if there's something to do the job locally?
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
