that pic of the 3/4 GTS-R is the sh*t (3rd pic)
but instead of an r31 should be a dr30
good stuff.
i posted them to give everyone an idea of what 75 degrees sideways could draw up for us and if he getsthe DR for him too as i said "i got that car to get this t-shirt"
  • Replies 2k
good stuff.
haha, it's my Nismo Widebody GTS-R concept based off that crazy Group B dr30 widebody. Except this is a M/R (mid/rear engine) car with two rb20det's stroked to 2.4ltr's joined at the hip to make an rb40dett 12 cylinder 4.8 ltr twin turbo :wassup:
a lot has to be made in the engine bay (trunk) but I will finish making it one day, and if you ask nicely i'll make a dr30 rs-x
car'nt take credit where credits not due, that design is ghostriders, but if you want i'll get a mate to draw up some of the ideas. this is some of his work..that shot is from the need for speed PC game and yes it is a r31 and r30 racing..mate drew the r31..his on line name is 75 degrees sideways..trying to get him to buy the purple dr benneys got forsale??
What about this sort of concept???
It's a take off similar to other club shirts, but just a suggestion.
What you think???
A third could be a 4 dr hatch on the bottom, then all available options would be covered.
A side profile silhouette would be better I reckon
BTW you're gonna cringe when I post a pic of what I did to my car lol
what about that idea of the silhouette but say below what ghostrider latest pic with the heading we have a hatch then below that a 4door then at the bottom a 2door or maybe swap that order?? cars only an inch and a 1/2 high??
something like these
now your just showing off..lol... i think it'll come down to $$ and what ghostrider has lined up with the printers (whats possible to be printed) it likeit to be alone the lines of the second shirt pic you posted?? i've got a shirt with the CORE r33 gtr on it that i picked up the last time i was in sydney... :D
hm yeh the silhouette type deal is a prety good idea i reckon. but like a modified silhouette like low looking sorta thing ... !
though i would like a front on iron mask type silhouette like that pic, that would be cool ... maybe side on silhouette of 4 door or watever on the front, and then front on silhouette of iron mask (like that grey one in the photo) on the back with R30 under it? i have photo of my car like that, but also has extra lower lip spoiler on the front from R31s to make it a bit meaner too =)
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
