  • Replies 2k
i can supply pics of my 4 door, just recently been painted but ive been a bit slack and not taken any photos.
also i tried asking in another section but didnt get much response. is a newer r200 diff centre able to go into a z31/r30 r200 housing?
Yes it can mike, but all the new LSD's are viscous and not worth sh!t for what we do.
The ratios are fairly high as well. I have a manual R32, S13 one here for next to nothing, cost me over $400 but will be glad to see the end of it. It's 3.692:1
adam_rsx - mine is one peice rubber lip. it doesnt extend that far it basically is like, from a side on view, like this --> |/
if u get it .. haha like sortof triangular, thinish rubber that bolts underneath by heaps of screws and goes around the side a bit, about 1/3 of the way back towards the wheel arch from the front.
haha hard to describe, but sounds more like the GTS-R thing to me? rubber lip, one peice, bolts on !
whats the differance between viscous and mechanical? all i want is for both wheels to move when i launch as im not a drift man. my current ratio is 3.77:1 on an r200 open wheeler and seems quite good. how much we talkin for the diff mate, and is it just a centre?
viscous suposed to work harder in a strait line on hard[good grip] surface or long gravel/ice roads.when cornering and in softer stuff[sand ice] the idea is the work like a tourque convertor and dont overload the wheel with grip.
Ive see 2 types one locks harder if the diff center liquid heats up.so there is no preload as such and one wheel free spins.
GTS-R had a one piece rubber bar/lip I think, I'm pretty sure that yours isnt one of them.  Looks more like the fixed fibreglass lip that some R31 guys fit... how far back does it extend?
some japanese and exported R31 have a small strip bolted[2 piece] under the apron.in africa it comes with a/c to add air flow.like honda prelues.
Since I know a bit on HR31's,I'll chuck 2c in. :(
The lip that lowers itself (Autospoiler) was standard on GTS-X's,and option on GTS. The GTS-R lower lip is a similar shape,but extends right round the 'corner' to the end of the bar.The GMS HR31 race cars had a one piece bar,that looks like a lowered Autospoiler(but its fixed,being 1 piece) There were also a couple of aftermarket "lips" as well,and no doubt Nismo/Autech,etc options as well. ;)
GHOSTRIDER:- what oil did you say you used in your diff? Some kind of full synthetic I think?
How does it preform? I assume you still use a stock mech centre?
And is your HR30 on the road at the moment?
tar
and everything lines up cool and the axels fit ok too? my life just got alot better if its true.
Since I know a bit on HR31's,I'll chuck 2c in. :)
The lip that lowers itself (Autospoiler) was standard on GTS-X's,and option on GTS. The GTS-R lower lip is a similar shape,but extends right round the 'corner' to the end of the bar.The GMS HR31 race cars had a one piece bar,that looks like a lowered Autospoiler(but its fixed,being 1 piece) There were also a couple of aftermarket "lips" as well,and no doubt Nismo/Autech,etc options as well. :)
tar
1. Mobil 75W/90 full synthetic is the oil. It performs as well as Royal Purple, Penrite, Castrol etc and is readily available for top up when necessary.
2. My R200 4.1:1 is a mechanical CUSCO centre LSD with 80 odd lb preload and I have a Nissan 3.9:1 as a spare.
3. No! the car is not on the road at present, but as soon as it is I'm heading your way sort of, got to see a mate on The Gold Coast.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
