  • Replies 2k
A set of MR30 panels and lights will cost you $200 and get it on the road, and will only take you an hour to swap over when you get the Tekamon stuff
Hows about no?? It left the road as a tekaman and its coming back as one as well!! Besides, im to lazy to swap panels around again, i just want to do it once and thats it!!
Besides that, the longer its off the road for, the more stuff that is getting bought for it!! My cooler is getting modified in the next week or 2 and hopefully i'll have that wastegate and manifold in the next few weeks as well!! Should be some fun soon :)
All thats different is the bonnet, lights, grille and filler panel, and the bonnet catch support
I'll continue to enjoy driving mine :rofl:
I do have a Tekamon bonnet, lights, filler panel spare atm, plus a set of guards
Hey, if you have the takemon bits spare, would you be interested in selling them?
I have an MR30, and want a takemon front end. are the gaurds any diferent to MR30?
I'll continue to enjoy driving mine :P
Wouldn't wanna lend me some stuff till i get mine would ya :) carn i know ya do :P
TEKAMON Vs STANDARD Fronts
For those that are wanting a performance vehicle?
The DRAG co efficients of both fronts are Tekamon/Iron Mask 0.37 yet the standard front with large head lights etc has 0.46.
Some perspective is the Z32 300ZX has a drag co efficient of 0.32.
The lower the number the less air drag.
Interesting,but also for consideration for those wanting a performance vehicle would be air flow to intercooler,radiator,oil cooler,etc....Surley the early style front would be better in that regard?
BTW,the mighty HR31 would have to have a pretty good drag c/e ,having flush fitting side glass,etc? Wouldn't have any figures on them would you?
I could... just dont put em through a shop :D
One guard is white and one guard is sorta gold though
Guards im not interested, neither a bumper, just headlights, filler panel and type c spoiler..im meant to have some coming last i heard they were being sent last week but i haven't heard anything since then*shrugs* who knows..If your willing to lend them rad, speed the process up, if not sall cool cool
There is an excellent article in Autospeed this issue about airflow through the coolers and believe it or not, it has nearly SFA to do with the size of the front opening (grille area) that determins the amount of airflow.
It has everything to do with the amount of pressure in the engine bay and how successfully you disperse it.
Lift the back of the bonnet about a cm and you will be surprised how much difference is in the airflow.
I am getting a couple of the gauges that measure the pressures and do the tests myself and then I will let everyone know the outcome.
DRAG, has an effect at 1 kph, but a much greater effect at over 100.
Take these "shopping trolley handles" that are on Hyundai Excel's for instance, a mate took the one off his misses's car and got an improvemrnt in fuel economy of over 5% and it has never been over 80 kph in it's life.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
