The highflow turbo will cost you 60% more to have done and there is down time while you are waiting for them to be done. The -7's are only $2250 for the pair or if you want to go get a pair of second hand N1's then they will do the same job.
yes im aware of that, but no one's compared it to the high flow's
As above - why bother?
You can get the Garretts for ~$1200ea.
For a bush hi-flow of GTR turbos its probably $700ea, and probably not far of $1200 for ball bearing cores anyway.
Im not sold on it being 60% more expensive... but the simple reason of its baasically cheaper to buy one news that are proven to work... choice is simple there
Bush bearing high flow is $1550 per turbo and BB high flow is $1800 per turbo.
Where did you get your prices from?
1.5k for a bush bearing hi-flow... wow.
hyper gear and so on, they are half that for a bush, as are many other suppliers/hi-flow around the 800-900 mark.
http://www.digi-hardware.com/turbocharger.html
I paid 1.1k for my GT30 when i had it rebuild a few years ago...
-New BB cartridge (if the shaft comes separate, new one of those also)
-New front wheel
-Machined comp housing
Turbine/turbine housing was OK.
Most of the cost is the cartridge at around 400-500 from memory and this was from Rotomaster here in Vic
ye but they are bush bearing and so on.. you have a GTR, you shouldnt be attempting anything on the cheap
?? its not like its risking anything with bush bearings, ill loose out a few hundred rpm on spool but until i get qualified i dont have a hell of alot of money. so they might just have to last a couple of years
and so what if i have a gtr?? do you think the bloke with his gts-t thinks any less of his car???
Its just my opinion.
You have a GTR, you put the best parts for the job on as you've got the best with a good head, plenum, TT setup etc. Why compromise?
Buying a GTR and not having money are two things that shouldn't be put together... and again, thats my opinion
i understand what your saying, im just trying to get best bang for my buck, after all that what the 32 gtr is know for, lol
so my story is im trying to get the car ready for doing a track series of some sort (maybe the street series one at barbagello that no-limits is organsing)
so stock turbo's have got to go, coz i dont want to have to rebuild the engine if the comp wheel blows up
so if i can save 400 or more on turbo's, that my new coil pack sorted :)
also getting vi-pex because im after decent protection for my car...
yeah true, didnt think of it like that, no idea what condition they're in tho??
btw can anyone see anything i've missed in preparing for the track
another point is ill over fill the oil for now untill i get new sump :)
selling the standard turbos will net you something towards some new -7's
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
