So I don't drive the GTR often, and in winter it sits under a cover.
Yesterday i get home from work and i notice a conga line of ants going up the power cord into the engine bay, with the trickle charger on.
the little bastards were everywhere in the engine bay, and a few in the cabin too!
What do I do to keep em off??
I started it up and ran it for about ten mins, then shut the bonnet... they seem to have evacuated a bit.
time will tell though, this afternoon, if they're still there...
https://www.sau.com.au/forums/topic/257762-fcking-ants/
As my car is quite old (see under my avatar, etc.) it used to get a lot of spiders and spider webs. Nothing much to worry about as they were always outside the car, and they were only garden spiders anyway. I guess the mould attracted them a bit too..
Anyway, what seemed to solve the issue (mostly) for me is driving it daily, or even once every two days. I've only had two spider webs since I got my P's. :)
All my webs prior to this were on the outside panels, wheels, mirrors, bumper bars, door handles, etc.
Your situation is difficult due to it being near mechanical and electronic things though.
I guess you could build a moat around your car..
https://www.sau.com.au/forums/topic/257762-fcking-ants/#findComment-4434882
Wash the car with a high pressure hose to get them off the outside.
Do you have a compressed air trigger gun? You can blow the ants out of the engine bay as I would not want to spray water in there.
Vacuum clean the inside of the car.
Since the car sits under cover, where ever its parked, spray Insect / Surface Spray 'around' the car (as if you were marking out a rectangle box).
That should keep the insects away and make sure to respary the same outline weekly and see how you go.
https://www.sau.com.au/forums/topic/257762-fcking-ants/#findComment-4434913
I had ant's in my old R31 Pintara (in the awesome color of "Nissan Racing Beige", it was one of those quality cars that was built in Clayton :) ), if the above don't work get some Ant-Rid.... it works ACE!
I figured the only reason teh Pintara got Ants, was the shear lack of powah and speed. :worship:
https://www.sau.com.au/forums/topic/257762-fcking-ants/#findComment-4435002
yeh surface spray around the bottom of the tyres works well (near, not on them)
Homebrand type cheapest possible surface spray around window frames will keep spiders out for at least 3 months.. its the most toxic crap tho, wear a mask.. I spray it on the vents and manholes etc too
Alternatively you could throw some ant sand on the ground
https://www.sau.com.au/forums/topic/257762-fcking-ants/#findComment-4435007
i had the same problem with my stagea not that long ago, cept my problem was i only left it for 3hours.
came through the quater panel down in the door and bang inside, i just got out the raid, spary anything and everything, paintjob also,
then went down to the car wash and used the vacum and washed the car, spraying high pressuer along any gaps.
not one any left :)
my mate also had an ants next under his rear seat of his VL (na, free) .. pulled the seats out and got BAYGON . about 1ltr sorted that out
https://www.sau.com.au/forums/topic/257762-fcking-ants/#findComment-4435024
have they made a nest in your car or are they just going walk about? A glass cup with a splash of coke or soemthing sweet seems to work for me. i have a drink, put the cup down, go outside to do some thing and when i come back its filled with ants that have been crawling around previously.
https://www.sau.com.au/forums/topic/257762-fcking-ants/#findComment-4435442
I know it sounds weird, but TalcumPowder drives them crazy! They hate it. Sprinkle some either directly on them or form a Talcumpowder barrier around your car. Cheaper than any insect spray AND wont damage your paint. Not sure if I would put it in your engine bay, but definately around it.
Just keep applying every few days. Its only because of this hot weather. When it starts to cool down, you wont notice them as much.
https://www.sau.com.au/forums/topic/257762-fcking-ants/#findComment-4435897
Lol @ talcum powder....so when you drive off it's like a crime scene!!
I'd put some ant rid solution nearby so when they take a whiff of that they evacuate the car and head for that instead.
https://www.sau.com.au/forums/topic/257762-fcking-ants/#findComment-4436019
i checked it last night, and it seems to be ant free... I'm taking it out for a long drive tomorrow, I'll freak if they start coming at me from the vents!!
I'll keep the ant rid and talc solutions in mind; also I heard they hate cucumber skins??
https://www.sau.com.au/forums/topic/257762-fcking-ants/#findComment-4436127
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
