Hi all,
I know this might sound a bit stupid, what is faster etc etc etc. .
But I have not yet finished my RB30DE (which have been told will make around 150kw at the rears from many credible sources). .
Now, as it is not finished (should be in about a month), the suspense is killing me as to what will be faster, my RB30DE in my vl or my mates 05 VZ SV6. .
He assures me that his car will wipe the pants off my vl with the RB30DE . .
Discuss. .
Also just a bit of info on the motor. .
Fully rebuilt,
Custom pistons, 20thou oversize
Spool rods with ARP rod bolts
Linished crank
ACL race series bearings
Balanced bottom end, pitsons rods crank flywheel pressure plate and balancer
Head is a R33 head with vct,
Cams 264 degree 10.7mm lift intake, 270degree 10.2mm exhaust
Very mild port and polish to remove casting marks on intake ports. .
Edited by ...Joshwa
https://www.sau.com.au/forums/topic/258175-rb30de-vs-vz-alloytec-36/
Power tp weight people!
Vl should kick it.
Is the vz auto or manual.
We had a vz alloytech, manual with rear mufflers removed, on the dyno. 150.5 kw at the wheels.
They are a heavy car with a tall diff ratio, something like 2.8:1 !!
You'll beat him.
Guys at no point in time has anyone mentioned comp ratio. What are you running in your RB30? This makes huge difference in NA engines...RB engines respond very well to ignition advance and therefore in the NA version, would also respond to high comp ratios...I am not an NA guru but there are many on the forums...Maybe do some searching and find out what will work well with your build...(before you bolt the head on that is....)
Nor have you mentioned area under the torque curve...Looking at peak power figures is close to meaningless when comparing how quick a car will be...
anyway my 2c worth...
VL Turbo Diff is 3.45:1 lsd centre I believe. See if you can get the comp up to 11:1 and a decent tune and then I would have my bets on the VL. More so if theres a decent length of track involved. Hopefully you wont sit there in wheelspin too much.
VL would have to weigh in 1250-1300 kgs ( I am guessing )
VZ would have to pork the scales at over 1600 kgs ...interesting
Keep us posted on any updates
Edited by GTR-32U
i think in this case the weight of the vz would cancel out the advantage in power
the rb30de with high comp would go well from the getgo, and with the advantage of 4.11 compared to the vz terribly tall diff youd prob nose it in front by 100kays/hour
the alloytec comes into its own at high revs and would be catching you very quickly
Righto considering I have a very hi comp RB30DE and a close mate of mine actually owns a Alloytec 3.6, I can tell that yes you will beat a standard one and one with very minimal mods i.e. exhaust and intake.
We went to the strip and I trumped him with my SOHC 30E (SOHC 30E = 15.6; Alloytec 3.6 =15.9) now in saying that the Alloytec 3.6's have a very very very shit clutch in them and will slip if you decide to even think about pushing them and a tall diff.
The alloytec make peak power very late in the rev range so basically they will keep up quite well in the high end of the rev range but down low, it's nothing but 30DE brother!
Awesome, its good to see someone else building a high comp N/A motor for a vl :D
How did you find the spool rods? From the website they seem to be a strong rod, just interested in what you/maybe your engine builder thought of them? I was thinking of buying a set too for my engine but was a little unsure..
Sorry for being a bit off topic, i think the vl will have it due to the power to weight ratio.. mines about 1210kg off the top of my head but it's just a basic SL model.
Keep us posted! :)
Kev
Alrightio. .
Sorry been at college today wasn't able to reply. .
Somebody asked what comp ratio it is running. . It will be around ~11.6:1, running an autotronic ECU. .
I cant comment on the spool rods in terms of use, as my motor isn't together yet, but I have them here sitting next to me and they look like they are great quality, and they also come with ARP rod bolts, which are essential for higher revs. .
And somebody mentioned torque curve.. Well I dont know yet as it isn't together and tuned yet. . Should be in about a month. .
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
