  • Replies 489
after speaking to geoff, he informed me that getting the fuel from csr was impossible as the big fuel companies have signed contracts for the next 6 months preventing anyone else purchasing e85, however they are not using it themselves... and the contracts are probably going to get renewed.
FARKING CARNTS!
aaargh! put new rims on the car and my guard roller broke before i got to the rears.... no point changing fuels while its scrubbing :)
got one here handy if you wanna grab it. give us a bell if you wanna drop past.
  • 1 month later...
update:
filled up with a tank of fueltown e85... which is supplied by powerplus (racefuel manufacturers)
the first thing you notice is the differing smell... its not as sweet as the CSR (united) blend, and smells a lot more "fuely"
we threw the car on the rollers and the AFR's were out by 1 (richer)
we tuned the car for the new blend, and ended up pulling out 10% fuel and 5 deg timing on the top end for the SAME power...
same dyno, same tuner, and pretty much identical ambient temps :)
i spoke to the guy that got fueltown onto 85 and he was saying that united rate their fuel at 104 ron, and powerplus call theirs 106! (the pump however says 104+ just to be on the safe side)
the differing smell is due to the fact that powerplus use wheatgrain ethanol, whereas CSR use sugarcane ethanol
both fuels are blended with 91 ron.
we did a comparison graph, with the CSR and the powerplus fuels, but i forgot to grab a copy...
next week when i'm back at status i'll grab them and upload them unless trent beats me to it :)
For the southland E85 Power is the same, but needs 10% less fuel and 5 degrees less timing to get said result. (red line represents first run with old e85 settings, too rich and too much timing)
im so glad you victorians get a choice of what e85 you can run... we don't even have it on pump :)
Still don't? Jebus... that's bad... :huh:
But then i live in the CBD basically here in Melb... as an example to get to Hoppers (where one of the servo's is) and back would see me using a 1/4 of a tank just to fill it up lol.
So whilst we have "choice", doesn't neccesarily make it instantly viable. A Sunday driver ye, anymore than that forget it IMO.
Friend of mine used to take two jerry cans with him just to 'justify' the trip even then there was one trip a month being done (car was only driven twice a week, not very far)
Hamish - given they only rate it 104+, various batches might change between 104-106 by the sound of that statement.
3 months the blend might die down a tad. At least the United seems to be extremely consistent... Fueltown might not perhaps.
Just something to consider.
Where is Fueltown btw?
So does anyone havee info when a few more of them will be stocking e85 ? reading this whole thread has really made me want to try it and also trent is a full retune needed to swap over to e85?
Id also be interested in what e85 could do with a stock turbo? any ideas Trent??? im running 13psi at the moment, so theres not really any room to increase boost i wouldnt imagine
Im in St kilda so fueltown isnt too far at all! and the car is only a weekender so it wouldnt be a hassle fueling up.
Im ASSUMING the injectors and stock turbo would be the main things holding me back? ive got an aftermarket fuel pump, which would be fine.
Would there be any worthwhile gains to be had???? if there is, ill be knocking on your door Trent!!!!
R31Nismoid dismissed me asking this question in another thread. Overall consensus of e85 fuel was that you seem to be able to get more power out of a particular sized turbo then what you should. Therefore its better to go on the smaller side for a particular power level.
Although R31Nismoid does have a point that a full retune is quite costly and there would be better ways to go to get more power (upgrade turbo).
As you said the problem will be the standard injectors as you need 25% more flow just to maintain your current power level.
And is it worth the risk of potentially ruining your turbo.
Edited by Harey
seraphyn_r33 - you would run out of injectors before you make any use of E85 on a stock turbo unfortunately.
So you would retune, and not make full use of E85 without fuel.
You should get around 230rwkw on a factory turbo with E85 @ a rough guess
ummm what?
    • So my rb is finally having more problems. 2 issues here but I'm here to just to mainly discuss the rattle noise. The other day when I turned on the car and when I take off or go in reverse, there is a temporary rattle noise but when I cruise, boost, idle it's completely fine no rattle whatsoever. I've also done all the servicing, all the health checks you can think of and it all passes with flying colours.  Also the rattle doesn't increase with rpm, it's only at a very certain rpm (slightly above 1,100rpm). My other car also has the same issue every once in a while. Changed the oil recently, no difference. Even took my oil to a lab and everything was quite good surprisingly. Timing belt changed a while ago to. Had the car on the hoist and can't see anything obvious. Tightened a couple of nuts on the exhaust manifold a couple of months ago. 2 different clips uploaded. One of them was supposed to another issue but I'll save that for another time. Thought I'd see if anyone had this same noise before, it's a bit hard to diagnose while it's intermittent. If I'm not mistaken, I think I had this a while back but can't remember exactly. I was thinking if it's doable I'll get someone to hold the throttle cable at 1,100rpm and hopefully it replicates the sound. rb25det rattle only.mp4 rb25det slow start + rattle.mp4
    • Haha wow, yes they do! Will sort tomorrow.
    • Yeah I’ll know when I take it for a test drive and I’ll double check the turbos as well when I have a look at it again.  Just thought maybe they might have done something in the head cause it looks like they’ve taken off the rocker covers 🤔 Thanks for your info!
    • As Duncan mentioned it's likely a remapped ECU, like the the one listed in the link I post earlier:  https://minkara.carview.co.jp/userid/444260/car/444612/2099320/parts.aspx He quoted 444PS with an unopened engine and twin GT2510s @ 1.1bar boost... sounds about right?
