damn... I'm nowhere near maxing them out at 360rwkw though... a little pressure bump would help... I'm not entering any dyno comps anytime soon so not too fussed with overall figure... just bang for buck there can't be many better ways to get another 30-40rwkw!... and its so close to my place I could run E85 all the time:)
  • Replies 489
When you say that you change in between tunes for petrol and e85 do you have to adjust your CAS aswell?
nope... just drain fuel, plug in the datalogit and the laptop, load the new map and reattach the fuel lines :)
wow that's a huge improvement... I bet you can really feel that on the road too
ooooh yeah! its a totally different car to drive.... much harder on the nitto's tho :)
http://www.zeitronix.com/Products/ECA/ECA.htm
This is an interesting product for those running alcohol fuels and want to map against fuel content.
Zeitronix sell the display for a GM flex fuel sensor that you can buy for around $300 AUD delivered from the USA.
It has a 0-5v analogue output so you can map a compensation map for E10 all the way to E100 and any variance in between (winter v summer blends) on your ECU. The motec could be mapped for fuel and timing in accordance to a % trim factor for a basic map out to protect the engine or a multi map for trimming at specific load sites, ie: load v rpm v alcohol
I have heard mixed reports regarding the southland E85, with a EVO not picking up the extra power (only 7kw) as much as the CSR ethanol from united in hoppers.
Regarding Phase Separation and E85s affinity for water absorption - has anyone experienced any problems with stored E85 for over a month? Reason being I would be more inclined to fill up a 205L drum of the stuff for a track day or just to fill up myself at the workshop. http://www.fuel-testers.com/expiration_of_ethanol_gas.html states that E10 has a shelf life of around 60-90 days due to the ethanol content (10%) wanting to absorb water. E85 could have a shelf life of around 3-4 weeks given its high ethanol content?
I have heard this too, but I dont see how it could absorb enough moisture from the air to cause an issue, as long as its stored in a sealed container. I have stored straight ethanol for years and it still burns and smells the same, vented tank would be different.
That Zeitronix box could be good for me, for mixing my own blends. It could be plugged into the Emanage input to control another map. Thanks for the find.
Are there any other ECUs that allow adding an extra axis to the fuel/timing map?
at home i store my ethanol in a sunoco tin, which is airtight, and i keep them on milk crates so the airflows and the temps don't vary too much
as far as the southland ethanol not making the power, that would be the fault of the tune on the day (tuner, weather, how well the tank was drained.. etc) or the motor itself or the mods... the stuff has a higher octane rating, and is made by a bigger ethanol manufacturer who have previously only dealt in performance fuels...
as noted in my car, and daniel's car - same power... exactly
also in my car - 10% less fuel - 5 deg less timing was required (daniel's was similar, but i'm not 100% on the exact details)
at work today i noticed that our flour is made by manildra group... so that pretty much confirms the wheat ethanol thing :)
i found a nice new jerry @ work ;)
let me know when you want it back...
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
