damn... I'm nowhere near maxing them out at 360rwkw though... a little pressure bump would help... I'm not entering any dyno comps anytime soon so not too fussed with overall figure... just bang for buck there can't be many better ways to get another 30-40rwkw!... and its so close to my place I could run E85 all the time:)
  • Replies 489
When you say that you change in between tunes for petrol and e85 do you have to adjust your CAS aswell?
nope... just drain fuel, plug in the datalogit and the laptop, load the new map and reattach the fuel lines :)
wow that's a huge improvement... I bet you can really feel that on the road too
ooooh yeah! its a totally different car to drive.... much harder on the nitto's tho :)
http://www.zeitronix.com/Products/ECA/ECA.htm
This is an interesting product for those running alcohol fuels and want to map against fuel content.
Zeitronix sell the display for a GM flex fuel sensor that you can buy for around $300 AUD delivered from the USA.
It has a 0-5v analogue output so you can map a compensation map for E10 all the way to E100 and any variance in between (winter v summer blends) on your ECU. The motec could be mapped for fuel and timing in accordance to a % trim factor for a basic map out to protect the engine or a multi map for trimming at specific load sites, ie: load v rpm v alcohol
I have heard mixed reports regarding the southland E85, with a EVO not picking up the extra power (only 7kw) as much as the CSR ethanol from united in hoppers.
Regarding Phase Separation and E85s affinity for water absorption - has anyone experienced any problems with stored E85 for over a month? Reason being I would be more inclined to fill up a 205L drum of the stuff for a track day or just to fill up myself at the workshop. http://www.fuel-testers.com/expiration_of_ethanol_gas.html states that E10 has a shelf life of around 60-90 days due to the ethanol content (10%) wanting to absorb water. E85 could have a shelf life of around 3-4 weeks given its high ethanol content?
I have heard this too, but I dont see how it could absorb enough moisture from the air to cause an issue, as long as its stored in a sealed container. I have stored straight ethanol for years and it still burns and smells the same, vented tank would be different.
That Zeitronix box could be good for me, for mixing my own blends. It could be plugged into the Emanage input to control another map. Thanks for the find.
Are there any other ECUs that allow adding an extra axis to the fuel/timing map?
at home i store my ethanol in a sunoco tin, which is airtight, and i keep them on milk crates so the airflows and the temps don't vary too much
as far as the southland ethanol not making the power, that would be the fault of the tune on the day (tuner, weather, how well the tank was drained.. etc) or the motor itself or the mods... the stuff has a higher octane rating, and is made by a bigger ethanol manufacturer who have previously only dealt in performance fuels...
as noted in my car, and daniel's car - same power... exactly
also in my car - 10% less fuel - 5 deg less timing was required (daniel's was similar, but i'm not 100% on the exact details)
at work today i noticed that our flour is made by manildra group... so that pretty much confirms the wheat ethanol thing :)
i found a nice new jerry @ work ;)
let me know when you want it back...
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
