Just being curious - what's the chances of finding a decent r34 m-spec nur? With the 34's getting down towards $40,000 now, it's really starting to seem affordable to get this fairly rare beast. What sort of price would be likely?
https://www.sau.com.au/forums/topic/258819-rarity-of-r34-m-spec-nur/
the M spec Nur's will demand a price premium over standard R34 GTRs, plus theyre very very rare as they were built towards the end of the R34 production.
only R34 rarer i can think of is the Z Tune version with 20 of them made
And N1?
The Nurs were approximately split 750 for V-Spec II, 250 for M Spec, so they're pretty rare and unlikely to come down in price that much if they're low kms and good condition.
Even the normal M-Specs are pretty thin on the ground, I think I estimated with someone else on here 350 or so built. It's in another thread in this section.
V Spec N1 had 45 built, with 33 of those being "road use" spec, the rest going straight to competitors for track use.
Z-Tune had 25 built, although a few more have apparently been retro-built (without the official Z-tune designation) at the Omori factory since the original run.
The rarest of all is the V-Spec II N1, of which 18 were built, and three of these actually reside in Australia.
I'm working totally off the top of my head here, so apologies if I've got my figures wrong.
i thought Z-tunes are the rarest of the bunch as well as being the ULTIMATE street GT-R
They are the ultimate, but they're not the rarest :(
It's splitting hairs a little, but technically the Z-tunes are Nismo built cars, and aren't considered GT-Rs. A bit like calling a HSV a Holden...
forgot about the N1 models lol. dont know much about them though.
im sure there were 20 Z Tunes built, but nismo kept one of them for its garage. dunno about more being built after the first run of 20 z tunes.
maybe the NSW owner can help us??? :(
How is your N1 'K'?
If it were mine, I'd have it chained to the floor at bedtime...
Or parked next to the Fat Boy in the lounge room.
Back to the term 'Classic',
a BMW M3 will not be a classic in the term 'Classic'; but an M3 CSL can be!
Both the CSL and N1 were lightened up for Racing.
So logic says haha that if you remove A/C, rear window wiper, sound system and insert forged pistons yadayada you can charge more $ hehe. But it's a whole lot more than what appears on the surface.
Summing up...
A M3 CSL to an M3 is similar to an N1 (or a Z-Tune) to a Nur IMHO
V spec II N1 specs & pics anyone????
N1 = Blueprinted Race Specification Engine.
N1 Block (N1 Block is identified by the number 24U stamped on it as opposed to 05U)
N1 Twin Turbos (Metal Ball Bearing, from factory 1.1 Bar boost = 15.9 Psi)
N1 Reinforced Cylinder Block
N1 Pistons
N1 Piston Rings
N1 Con-rods
N1 Oil Pump
N1 Water Pump
N1 Exhaust Manifold.
No ABS, A/C, Radio/Cd, rear wiper, carpets and a factory standard Carbon Fibre bonnet was installed to reduce weight.
V-Spec II Nur's and M-Spec Nur's are based on the V-Spec II N1's but WITH ABS, A/C, Radio/Cd, rear wiper, carpets and a factory standard Carbon Fibre bonnet.
Pics ask Iron Chef, he's got one... Damnit I want! LOL! :wacko:
I believe the N1 Engines are hand built so they are very refined / well balanced engines.
get the V-spec II nur instead, easier to get a hold of one as there are more around and worth more in the long run anyway, mainly because it is the 'proper' GTR and not some GT cruiser version which the M-spec is supposed to be (i.e. a little softer).
I believe I saw an M-spec Nur at auto salon or something last time here in Perth, nice looking car :wacko:
I would've thought mint condition Nur's would only increase in price. As they're so rare and becoming somewhat of a classic.
All depends on the timeframe. At this time, they are definitely "undervalued", primarily due to several factors like the economy and the arrival of the R35. Once you give it time, (it could be 5, 10, 15 or 20 or more years), I have absolutely no doubt it would appreciate in value.
Unfortunately this cant be said for "normal" R34 GT-R's such as your V-Spec, V-Spec II and vanilla specs purely for the fact that thousands were produced.
I believe I saw an M-spec Nur at auto salon or something last time here in Perth, nice looking car :)
I totally disagree with that.
I dont understand what you mean by "proper" GT-R. Bother are almost identical cars except for a carbon bonnet with V Spec II and a full leather interior and softer struts with the M Specs. I know what i'd prefer and thats sitting on some nice leather seats. The leather they used is not some cheap ass B grade leather as well. It's very soft and high quality.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
