but what if the skyline had, like, sic cat back zorst and some HGE boost. Wouldn't it win then?
I heard the F1 cars don't have much torque, so maybe if they raced on the uphill :confused:
Originally posted by Silver-Arrowz
the ferrari wins cause it's got more stickers. More stickers = more HP.
Yeah, you're right about that, you should see how many stickers are going on for Dutton rally.....we are sure to kick everyone's arse
Originally posted by Rezz
This thread should be titled "Ferrari F1 car opens up a can 'o whoop ass on pit crew member"...:P
:bahaha: yeah, I would have except there wouldn't be a "vs" in the title :)
Do you reckon that crew member made a mistake at the last pitstop and it was payback time?
bit of insite into f1
An F1 car is made up of 80,000 components, if it were assembled 99.9% correctly, it would still start the race with 80 things wrong!
Formula 1 cars have over a kilometre of cable, linked to about 100 sensors and actuators which monitor and control many parts of the car.
An F1 car can go from 0 to 160 kph and back to 0 in 4 seconds.
At 550kg a F1 car is less than half the weight of a Mini.
In an F1 engine revving at 18000 rpm, the piston will travel up and down 300 times a second.
Maximum piston acceleration is approximately 7000G (humans pass out at 7-8G).
Drivers haven't had to resort to pressure suits like fighter pilots because they only experience high G's for very short periods of time.
If a connecting rod let go of its piston at maximum engine speed, the piston would have enough energy to travel vertically over 100 m.
If a water hose were to blow off, the complete cooling system would empty in just over a second.
Gear cogs or ratios are used only for one race, and are replaced regularly to prevent failure, as they are subjected to very high degrees of stress.
The fit in the ****pit is so tight that the steering wheel must be removed for the driver to get in or out of the car. A small latch behind the wheel releases it from the column. Levers or paddles for changing gear are located on the back of the wheel. So no gearstick! The clutch levers are also on the steering wheel, located below the gear paddles.
To give you an idea of just how important aerodynamic design and added downforce can be, small planes can take off at slower speeds than race cars travel on the track.
Without aerodynamic downforce, high-performance racing cars have sufficient power to produce wheel spin and loss of control at 160 kph. They usually race at over 300 kph.
The amount of aerodynamic downforce produced by the front and rear wings and the car underbody is amazing. Once the car is travelling over 160 kph, an F1 car can generate enough downforce to equal it's own weight. That means it could actually hold itself to the ceiling of a tunnel and drive upside down! In a street course race, the downforce provides enough suction to lift manhole covers. Before the race all of the manhole covers on the streets have to be welded down to prevent this from happening!
If you've ever changed a tyre, you know that you have to jack the car up off the ground to be able to replace the wheel. And it takes ages. F1 cars have integrated pneumatic jacks in the chassis (rather than the manual jacks normal cars have) - two in the front and one in the rear. By connecting a pressurised nitrogen hose to a port located behind the driver, the pit crew can jack the whole car up in less than a second when the car stops in the pit.
The refuelers used in F1 can supply 12 litres of fuel per second. This means it would take just 4 seconds to fill the tank of an average 50 litre family car.
Top F1 pit crews can refuel and change tyres in around 3 seconds.
Race car tyres don't have air in them like normal car tyres. Most racing tyres have nitrogen in the tyres because nitrogen has a more consistent pressure compared to normal air. Air typically contains varying amounts of water vapour in it, which affects its expansion and contraction as a function of temperature, making the tyre pressure unpredictable.
During the race the tyres lose weight! Each tyre loses about 0.5 kg in weight due to wear.
At ~ 350 mm wide, F1 tyres are much wider than normal tyres (~185 mm wide).
Normal tyres last 60 000 - 100 000 km. Racing tyres are designed to last 90 - 120 km.
A dry-weather F1 tyre reaches peak operating performance (best grip) when tread temperature is between 90°C and 120°C. At top speed, F1 tyres rotate 50 times a second, or 3000 rpm
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
