First pics of the recently finished Benson Motorsport's supported Nismo 400R of David Ayers and Robbie Bolton all ready for Targa Tasmania 2009
Some of the paint was a bit of a last minute rush due to freight issues and the kit being damaged in transit... it will be refinshed post event, but I think you'll agree it looks awesome!
  • Replies 652
Posted Images
Finished our recce, what an adventure! treatourous rain, fog, rain, wind, did i mention rain? oh and recce in the dark is no fun! Our recce car got a flat 3/4 through strahan and we were stranded cos it had no jack, wheel brace or wheel key. Yay!
Ill give everyone a tip ive changed some of my notes to say f**kING SLIPPERY!!!! (no joke!)
wow wtf??? snowy. any damage tot he front??? befor you got back ont he road the dip looked pretty bad. hope all is good.
hope you guys have fun. owuld love to make it one year for a watch and support :(
Mate i am not a violent bloke but i would have stopped at the brow and had words. Farking idiot. LOL i am a big man with Dan to back me up...right Dan? :D
not violent my arse. I know of a certain pimply faced youth who has a scar from where you sconned him with a muffin (pun intended)! he is still scared whenever baked good are around.
Looks great Stu!
Here's a quick vid of some interesting times we've had with the locals whilst doing recce. Most love the R35 but it seems some not so much so...
http://www.youtube.com/watch?v=Xq0QmfaA_Z0
;) wooah I would have definatley changed my jocks after that close encounter!
Best of luck everyone, I will be at the finish so might meet a few if Timmy is kind enough to introduce me haha
You know the sad thing is yesterday I was diagnosed with a hiatis hernia so I almost might have to start becoming a health freak.
Mind you they say one of the biggest killers for me is coffee and I'm not giving that up for anything! LOL
That's along with spicy food, fatty food and alcohol - which means if I was to take all of them out of my current diet I'd be left with just the water I drink each morning in the shower.
I have had that for a couple of years mate. Its not a whole lot of fun, you will generally feel pretty shit each day especially in the morning but you adapt and don't notice it so much eventually. Get on Somac 40mg makes life a whole lot more enjoyable. :)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
