  • 1 month later...
  • Replies 652
Posted Images
I hear you. Everyone makes a mistake at some time, and it's my personal opinion that what goes on in the car, stays in the car.
I have a theory, and it may be a weak one, that when Rod was saying"where was the f**king chicane call?", he wasn't so much asking Sammy as asking himself, like, where was it in his brain and why did he miss it? It's only a theory, mainly because I could hear myself asking myself the same question out loud if in a similar situation.
Regardless, the first question after a hit like that should be "are you ok?".
2. I definately would have got off the brakes and just hit the chicane. Hitting a chicane isn't the end of the world, flat spotting all four tyres and going hard into the scenery is. Check out the skid marks in Sav's video at 3:34!
I know it's old news now but I noticed that sammy had posted up clear footage of the acco at the end of june, she's also said she wont nav again. and I wouldn't either. the first thing SHE said was "are you ok". the first thing he said was "yeah I'm ok (no question about her) and where was the f**king call". well there was the first chicane call, then the 100 meter chicane call, then the 'get off it' call. how much help did he need, and instead of just trying to wash off as much pace as possible and plough straight into the plastic barrier it looks like he has a nice tug of the wheel which sets the car into a massive tank slapper and points him straight into the tree. yeah he'd be pretty shaken up after a big acco and could be forgiven for a few fks and cnts but she had the decency and presence of mind to ask how he was, all he did was basically this was your fault. he must have had his ipod on max if he missed those chicane calls.
http://www.youtube.com/watch?v=ePgtXQEHxWE...feature=channel
jenna has indicated that she wants in( lol)
if i can find a gtsT with a rol cage ill be there next year
other oprtion is to put a cage in jennas car :)
well turns out im stupid :mrt:
and i have now aquried a gtr to cage up
should have listened to my own adivice and got a gts
anyway i am building it to CT spec so i can come play the lets blow up engine game with duncan
should be fun!!!
im excited
ill be aiming for a TT run in 2011
im excited
mainly for the sidz i will get to do once the 4wd dies!
And true to her word she has now entered in next years season as a driver - in a '91 Nissan GTi-R.
:mrt:
yeah I saw she bought a neat white little GTI-R Pulsar, has some good bits, LSDs, Close ratio box etc. if set-up well and with the right bits they are a good little car. 1200kg, good SR20 with quad throttles, all the good bits etc, AWD they are pretty competitive. their real downfall is the lack of popularity means there is no big amount of aftermarket support or knowledge pool like you have with other models like EVOs WRC etc.
she seems to be a good driver so hopefully she does well. :)
    • How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate?  How is it launching with it, any dragy times from 0-60? 60ft?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
