hey everyone
the following people are confirmed as a entrant for the SAU Display:
Myself - 34
Krishy - 33
Troy- 34
Luke - 34
Shane - 32 GTR
Martin - 32 GTR
Ruby - Stag
Ben & Nene - Stag
Anthony - R32
Andrew - 34
Mitch - 33 (ill keep on the list until you let me know for sure Mitch)
Big thanks to everyone for entering :D
  • Replies 499
Posted Images
hey but atleast i gota decent ride to lure em with, owwww how u like me now mofo
Dan does your daily pull bogan hotties ???? gangsta hole and rain leaks ?
Dave , fix your car mate, I havent seen it in ages...lol
you keep tellin yourself that dan. :P
its gettin there mate, got john from marvey tech dropping by on saturday to sus out some wiring, should have whats left of my pipework done by this arvo, then i just need to install a smaller battery, relocated one of my HID ballasts, put the front end back together and i should be back terrorising cara and her car shows adelaide in no time.
no best jap this year?
i dont have a car to enter anyhow.
i think u r refering 2 the other show and shine which is usaually grand final weekend every second year...
which is the one us local lad's worry about cos gives us more time 2 make our cars betta
puts up hand to take krishys spot, ill even go get a spray tan to make it look more convincing :banana:
Umm i am already committed to going with the rest of the SAU peeps for the show and getting absof**kinglutely hammered
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
