Just to annoy you Bris - here's the footage on how easy it is to run a 1.50.1 in a GT-R :nyaanyaa:
http://www.viddler.com/explore/Snowmann/videos/2/
Thats why i couldnt enjoy a GTR, it all looks easier then it is, and there is way too little drama :(. I would rather pilot my thing....keeps you so much busier
  • Replies 95
Posted Images
heh yeah i'm with you bris....
thats probably one of the most boring vids i've eva seen....
its all about the excitment...
I'd much rather be excited doing my 2:04 than be bored doing a 1:50....
On that note.... Firman picked up a 2:04.55 in the 180B
my current best is a 2:04.97 :nyaanyaa:
keeping in mind that my car has 2.5 times the power of Firmans!!!
Seems I have some work to do....
Thats why i couldnt enjoy a GTR, it all looks easier then it is, and there is way too little drama . I would rather pilot my thing....keeps you so much busier
Lol 1:50 might be easy in a heavily modded GTR by RP but try it in a fairly std one and you won't be bored chasing a 1:49 :nyaanyaa:
speaking of the noise... that is a flawed system. if tim can get away with gate and scotsman gets pinged with la di da benno special super silent exhaust then somebody is smoking too much crack.
we stay less than 2k from the track and there is no way we would be able to hear the gtr more than tims or brisbys car.
I like the current system :nyaanyaa:
Strange that, but must just be the frequency it's at. I didn't have EPA issues at Sandown either with the open 'gate.
Sorry to hear Matt, hope the engine is all good.
It's not easy - its just smooth :thumbsup:
There's a difference. Sometimes backing off a bit and being smooth is actually faster. You should try it one day Bris :devil:
Ah, something about the grass being a different colour over other side of the fence...you needed to have driven my car when James and Juz drove it with the Bilsteins and old suspension. You often joke but i dont think you realised just how hard my car used to be to drive.
I can promise you that the vids of me driving it required me to be smooth and delicate with inputs, it may not look like it but i was. Well , i was driving it smoothly to the best of my ability. Just ask Juz how much she enjoyed drivng it with the Bilsteins?
It was so much better with the new suspension, and should be a lot better now i have most of the bushes etc replaced so no more slop.
You can see in the above vid,
You can see in the above vid, half the reason it looked all over the place is the fact that it used to pitch all over the place on its soft suspension at high speeds so slight throttle adjustment gave it pretty bad lift off oversteer. Anyway, you are winding me up....which is not a nice thing to do to a guy that is itching to get his car back on the track. :)
Had a really good day, First time at PI and it was great.
That track is just so far above anywhere else I have drivin.
Russman:
Slow time thanks to super cheap drift spec tires on the rear and ok streets on the front, cold track , rain , mass oil attack and first time there, Although it was good to have shit tires in a way as It helped me to find the smoothest line around which will be good for next time.
Frysy:
Harden up and get some gate! lol .
I honestly dont know how Scotsman got done and I didnt, I can understand in the morning sessions as I was pussy footing it around but in the arvo I thought I would get done for sure. luck of the draw I guess.
Bris , im keen for us to attack PI side by side im sure that will send the db meter into overload.
Very enjoyable day for me , feel sorry for the blokes who took bent cars home.
sandown 2 weeks . should be good.
Anyone got 2nd hand semis they wanna sell ??? 245-255 x 17 ??? LEt me know
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
