Finally onto my open licence and without loosing a point !!!
Sure I drove a non-turbo silvia for the first 1 1/2 years and a gts-t skyline for the remainder. I've had fines and warnings for stupid things likes driving without headlights on and driving "erratically" - before the new laws were passed.
I guess i've had some luck with speeding fines but other than that I drive quite sensibly.
How many of you guys are on your opens? and in which state?
https://www.sau.com.au/forums/topic/26061-my-three-years-is-up/
Yeah, I have been on my opens for 6 yrs now, have had plenty of fines and had my license suspended once. All this while driving minis and geminis. In the two years of Skyline ownership I haven't lost a point, oh yeah have never been in an accident either.
Have had my licience for 8yrs (last 2 with the skyline), last 5yrs working as a field tech. doing about 1100km p/w of driving, have NOT lost 1 point and no accidents. Not even a parking ticket, lol :D.
Have coped 2 canaries though (with previous two cars):)
That is almost identical to my story! 8 years with a license, last 2 being with the Skyline. I spent the last 2 years working out of town (so not quite a field tech), and therefore did a huge amount of driving - yet I have never lost a single point on my license, had any parking tickets or any accidents. I have been pulled over for speeding a couple of times though (once was 30km/h over in an 80 zone and he let me off cos it was late and it was a straight road)
I've only copped 1 canary - but for me it was on my Skyline :(
ive just lost my liscence for the third time, im on a good behavour liscence, which is 2 points for one year instead of doing the time, when i do get my liscence back i have to do 3months automatic suspension for 45and over, and then they take a further 9 points of my new licence when i get it back, if i dont do anything wrong, by mid 2006 i should have a full 12points, what can u do but slow down, im lucky because they wanted to take me to court and reveiw my licence and take it away from me for three years due to having 3 or more major fines in a space of three years, over 45, burnout, etc, ive got three burnout, two over 45
Originally posted by B-Man
NSW Gold Licence Holder for 18 years.
Currently, only 1 point down on my licence.
Geez I'm old !
I can beat that, 19years, no points down
I am older:p
and WTF is a gold liscence, is it like a amex gold card - give you special discounts on fines of something:)
He he - another oldie - I was beginning to think that Neil, Dino and I were the oldest phukers on this forum ! :) he he
Yeah - Gold Licence - You get a discount on the number of points taken off for speeding :D j/ks
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
