I rang them - It's like hype said :
Stage 1 - $2200
Stage 2 - $2400
Stage 1 for street use - more drivable
Stage 2 for strip use - less drivable (assuming this means more boost comes on later)
Both represent significant gains over standard - Not sure what 'significant' means.
Both sides of the turbo are highflowed using exisiting housings. Ceramic turbine chucked our and replaces with a better one - All bearings replaced.
Not sure, but I saw in another thread that a Hi Flow job coast $1300 - maybe that was just the compressor side ??
I spose when you are talking about a turbo - it's worth paying a bit more to get a professional job. Plus - it's still cheaper than a new/bigger turbo - Plus the look remains stock.
I think the other turbo for 1300 was a thrust bearing and GCG do ball bearing. It would be interesting to see peoples thoughts on which bearing to go for. If it is worth the cost. This could be for two reasons i.e. wear on the bearing, if this is a concern do thrust bearings wear out quicker and how long would they be expected to last ie 15psi. And in theory ball bearing should spool quicker all things equal however has anyone had any lag due to going thrust bearing conversion.
It all comes down to money and in this instance up to a $1000 more for the GCG ball bearing version.
For what its worth...
on most engines thrust bearings are fine if you dont mind the possibly slower boost response.
However i hear that RBs arent renowned for their high oil pressures, and when combined with a thrust bearing turbo running @/over 1 bar have been known to wear thrust bearings, internals pretty quickly.
The higher boost levels and lower than ideal oil pressure force the oil film to disperse allowing metal to metal fouling of the thrust bearing.
Anyway thats the advise ive been given and it seems sound enough from a logic point of view.
Anyone read the article? What did you think? I rang Kyp from ATP and he wouldnt tell me any specs however guaranteed 220rwkw with my setup. They had a car produce 238rwkw. Well priced under 2k including match porting exhaust. Still only bush style bearing.
Anyone had or heard of any experiences with these guys.
Greg.
I picked up a second Hand HKS t04e for $400, and just need an external wastegate, even if it needs a reco that anly costs about 700. The manifold modification is not too hard if you have the right tools, I am macking a steel block that will get welded to the std manifold, and the gate and turbo will bolt to this. You could probably gat something similar made for about $400.
I rang the dude at Port Kembla. He reckons he can do a reco & small hi flow for $800 (keeping the ceramic turbine) But for $1200 he can do a much better job and replace the ceramic turbine.
Might be worth investigating a little more.....
Originally posted by meggala
that was my thought the only thing with the hiflow is it bolts straight up. with no mods needed
cheers
meggala
Geez, Garret GTs even HKS turbo's (when got from Nengun) are about that price "NEW". I guess its cheap if a big part of the cost is labour to remove and fit the turbo. Otherwise I'd go buy a new one.
The GT25's are 'bolt on', will make more power and be more reliable.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
