Morning Mangs,
Scarnon?
Saw a douche in a ute plow straight through two red lights this morning. Pulled up next to him at a later set of lights (there was cars in front of him so he couldn't run that one) and saw he had a kid in the passenger seat (maybe around 10?). F*cking drop kick.
<---- wants cruise in his R33...anyone know if they came with a factory one, or what the best option is?
see it as an option. that said anything is possible.
I'd guess you could get factory cruise in the 33's you could in the 31's
see above :)
Farking Mondays.
agreed.
Didn't get any time to get out there yesterday.
Taking the car to Chris this afternoon anyway to get a few things sorted, so might get him to have a look at it.
your brake lights work now. not much else does at the moment. talk more about it this arvo.
2011 LHD 5.4 lt blue oval drop top... technology in this thing is seriously pissing me off. ford oz is zero help answering a simple question...
(yes I'm having fun.)
having had a closeer look at it, I will gladly take it off your hands
you can even keep mine instead
lol.
Just finished 9hrs of Tsukuba. Bi-Winning, Tiger Blood, n shit.
Next up... 24 hours of Le Mans... >_<
yer i was going to be a douche and finish off his 9 hour enduro last night, decided against that, i cbf doing it.
Seriously today was a banger of a day, spent most of the day on a Lotus Cup 260 that had electrical issues, some knuckle dragger had unplugged the wiring for the "accusump" and rewired it all wrong, so it wasn't working, on top of that the accumulator was actually leaking so once i got it working again i had a minor oil weep, it never ends. Damn fun on the road though :banana:
Keen for 24hr Le Mans!
What do you reckon, 4 drivers and a plentiful supply of alcohol?
24hrs of Nurburgring is the race after Le Mans, but it will take a while to unlock that one... :(
What else is new?
Never knew Toyota Corollas had oil accumulators..
Factory option ;)
P.S. Morning Mangs, TFIT, etc.
Lol Dan, are you going to keep supporting those 'lotus' renaults as they send themselves broke?
http://joesaward.wordpress.com/2011/06/01/a-log-jam-at-renault-f1/
Looks like the upshoot of the recent court case is that they cannot rename their constructor to 'lotus' next year, they'll have to keep calling them renaults, or something else at least.
http://joesaward.wor...-at-renault-f1/
I'll raise you a few nissan navara utes with CRACKED front suspension mounts. think renault had somthing to do with building them as well.. (have two trucks here with the same issue..)
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
