Morning Mangs,
Scarnon?
Saw a douche in a ute plow straight through two red lights this morning. Pulled up next to him at a later set of lights (there was cars in front of him so he couldn't run that one) and saw he had a kid in the passenger seat (maybe around 10?). F*cking drop kick.
<---- wants cruise in his R33...anyone know if they came with a factory one, or what the best option is?
see it as an option. that said anything is possible.
I'd guess you could get factory cruise in the 33's you could in the 31's
see above :)
Farking Mondays.
agreed.
Didn't get any time to get out there yesterday.
Taking the car to Chris this afternoon anyway to get a few things sorted, so might get him to have a look at it.
your brake lights work now. not much else does at the moment. talk more about it this arvo.
2011 LHD 5.4 lt blue oval drop top... technology in this thing is seriously pissing me off. ford oz is zero help answering a simple question...
(yes I'm having fun.)
having had a closeer look at it, I will gladly take it off your hands
you can even keep mine instead
lol.
Just finished 9hrs of Tsukuba. Bi-Winning, Tiger Blood, n shit.
Next up... 24 hours of Le Mans... >_<
yer i was going to be a douche and finish off his 9 hour enduro last night, decided against that, i cbf doing it.
Seriously today was a banger of a day, spent most of the day on a Lotus Cup 260 that had electrical issues, some knuckle dragger had unplugged the wiring for the "accusump" and rewired it all wrong, so it wasn't working, on top of that the accumulator was actually leaking so once i got it working again i had a minor oil weep, it never ends. Damn fun on the road though :banana:
Keen for 24hr Le Mans!
What do you reckon, 4 drivers and a plentiful supply of alcohol?
24hrs of Nurburgring is the race after Le Mans, but it will take a while to unlock that one... :(
What else is new?
Never knew Toyota Corollas had oil accumulators..
Factory option ;)
P.S. Morning Mangs, TFIT, etc.
Lol Dan, are you going to keep supporting those 'lotus' renaults as they send themselves broke?
http://joesaward.wordpress.com/2011/06/01/a-log-jam-at-renault-f1/
Looks like the upshoot of the recent court case is that they cannot rename their constructor to 'lotus' next year, they'll have to keep calling them renaults, or something else at least.
http://joesaward.wor...-at-renault-f1/
I'll raise you a few nissan navara utes with CRACKED front suspension mounts. think renault had somthing to do with building them as well.. (have two trucks here with the same issue..)
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
