There are certainly other options out there, but not many.
For the MY11+ GTR with the 390mm front rotors you only really have Alcon and AP rotors as a direct rotor replacement, though these still require new hats.
The 390mm fronts are better than the 380s on the MY09-10, but still prone to cracking, like this after a couple of days on track:
  • Replies 151
Posted Images
^ same as the r32 rotors - crack across the cross drill section.
i noticed that the alcon & ap rotors are slotted for the r35, so why have nissan cross drilled rotors from factory? you wonder if this was a marketing ploy for replacement purposes / ongoing business (similar to that of the iphone with glass screen which does not bounce well)
I wouldn't worry about forking out $$$$$$ for rotors. When mine are done and dusted, I'll be going with DBA 5000's.
Guys on NAGTROC have said nothing but positives, I've used DBA's on my Subaru STi's for track and daily work with no issues what so ever.
http://www.nagtroc.org/forums/index.php?/topic/66648-dba-5000-series-rotor-ring-set/
http://www.nagtroc.o...rotor-ring-set/
DBA's are great & I use them as well. $325 per rotor makes it almost 90% cheaper than the oem's :)
Australia have developed A LOT of good upgrade parts for the legacy GTR's & seems to be the same trend for the R35
I don't know why they are drilled, the holes fill up with brake dust after a few track sessions anyway.
I asked DBA about 390mm rotors a few months ago, they were waiting for an OEM sample to work with...So doesn't sound like they will be available anytime soon, but I will certainly get them when I can.
Don't ask the Aus DBA boys, you gotta go DBAusa.com to get the good stuff. They make them already, this is direct from their USA website.. Mind you these fit up to Feb 2011 build cars.. Anything after nada!
Front Rotor
DBA 52320BLKS DBA 2 req
DBA 52320GLDXS DBA 2 req
DBA 52322.1S DBA 2 req
Replacement ring to suit OE hat DBA52322.1XS DBA 2 req
Rear Rotor
DBA 52321BLKS DBA 2 req
DBA 52321GLDXS DBA 2 req
DBA 52323.1S DBA 2 req
Replacement ring to suit OE hat DBA 52323.1XS DBA 2 req
Edited by Wardski
why wouldn't you go with the AP's? i've used quite a few sets with nil issues. Not trying to cause a shytestorm but nearly every DBA i've used (admit on other cars) have warped pretty quickly. Might be the way it's bedded in (my fault perhaps) but from my perspective the DBA's are more fragile in that sense. I wouldn't buy them, at least not for track. For the street, sure.
DBA rotors can be hit n miss, but this was more like 5 years ago. I've had about 5 sets on the STi, and not one have had any issues - other than wearing down too fast - but that was probably more my fault than anything else :whistling:
  • 1 month later...
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
