  • Replies 105
RH9 is in Qld now
Big block blown valiant would be kinda cool for Vin
its only small block but still tuff.
will send some pics tomorrow .
Edited by STRETCH
I reckon Z-tune would be the winner for sure. or an R35 wouldn't go down too badly I think. I have one but not sure about lending it out! lol.
and for vin maybe some aussie musscle. he's surely had plenty of yank cars by now. maybe a nice Ford GT (at least they are 4door, and there are some amazing GTHO replicas/real deal out there). or maybe a nice monaro (either old or new) or a worked torana etc. lots of show quality ones out there.
ps, i'll be offended if you don't remember who I am big boy... :D
anyway, my R35 (pics taken back when it was at the showroom in japan).
haha at the 31, shame this is in Sydney, my mate has a mad jet black Dodge charger, with a huge f**k off blower and runs 10's without N20, the thing is absolutely mental, exactly the same as the car Vin drove in first fnf
oh im not joking and ive changed the rims to suit the show!!
looks hot fatz. let me guess, you could only afford 3 TE37s as you spent the 4th one on beers. now saving up to buy a new 4th TE37 and complete the set. keep at it big boy.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
