Its honestly just sitting pretty ATM. Just PM me an offer and I'll consider it.
It needs a basic clean and recheck with a straight edge and its good to go. Valves/springs/retainers still in place. Will need to look for the buckets, cams are VCT and rusted.
As stated, welded to suit RB30 block, not non VCT yet using typical R33 DET head means easy fitment with Freddys ETC
considering just getting a Kai highflow done on my 0p6 stocker.. should do atleast 270rwkw and full boost around 4000rpm and its LITERALLY bolt on/off.. $1370 and thats it. or is it, i dont know how the stock intake would hold up to it - Stao?
anyone have any updates on their HG turbos?
Not any real updates as of yet, but may have figured out a possible fix for my problems after speaking with Matt from NIStune. The TCS error code is possibly causing problems by pulling fuel unexpectedly. This may be fixable by reprogramming my board with a Stagea image. The boost sensor DTC is similar story, the stock ECU needs the signal from the stock solenoid because it uses boost control tables, but that was removed when we installed my engine and the Greddy Profec.
So I'm slowly working through my issues, nothing concrete yet though.
Why don't you just take brad's advice on how to fix it?
Edited by SimonR32
He didn't tell me anything that I didn't already know. This was his last PM to me:
The Trc code. You need to make sure its plugged in. Its the Brown plug on the back of the TRC motor. Not the main TPS plug at the front. If you dont want TRC you can get rid of it completly but that a little hard to explain. This should rectify both of you abs and TRC codes.
My Car has a Greddy plenum so Its not the same . I think it still has the Abs DTC in there as I dont have TRC anymore.
I Never had it tuned with these faults so I dont know if they would have affected it at all. I fix all the problems
Beforehand as it put the engine light on.
But I do not have TRC, it's been deleted. I have no intention of wiring it up either, I'm not interested in it and the plan is to go forward facing plenum in the future anyway where it would just have to be deleted again. I did ask him how he fixed it with TRC disabled but never got a reply.
Edited by Hanaldo
Yeh see that would mean wiring everything up. I've got the throttle body and the sensor on the back of it but it's not connected to anything. Would work if I was doing what he did by going to forward facing and the stock setup was all there.
May be easier to use the Stagea image if it works.
Hanaldo, i have the stagea ecu in my R34 for unknown reasons if that helps. Its running R34 maps though and Nistune. No probs, just dont have TCS/Slip, no light nothing..have the dual butterfly in the Tb.
Hey guys,could anybody tell me the size of the dump pipe bolts?
I've just ordered a jjr 3" bell mouth (rb25) and searching has proved fruitless for me, unless im typing in the wrong phrases.
I'm not at home for another 2weeks and would like to have everything waiting for me when i get home.
Cheers guys
P.s Great thread,lots of info
They are M8x1.25 from memory, someone confirm??
It doesn't say if the order comes with anything else so I ordered the permaseal full gasket set for the upcoming highflow purchase.
After reading a few posts on the subject, I thought it might be worthwhile replacing them. If they don't need replacing then spares will always be handy to have.
Thanks for the help guys, M8 1.25 it is. I'll try and get varying lengths and the 10mm head is a great tip Jez.
Can u not use the stock ones? I got bolts n crappy gaskets from just jap when i got my jjr pipe.
You can, but keep in mind that these bolts are 12+ years old now, they've seen a lot of heating up and cooling down. I considered myself very lucky when I didn't snap any of them getting my turbo off for the first time. Better to just replace them in my eyes, makes future removals so much easier.
I actually changed to allen key studs on my last turbo install. Makes getting THAT bolt out a breeze :D
Hi Tao, wondering what the differences are between the SS1 and SS1PU? How much would it cost to make my SS1 into an SS1PU? Is the SS2 a completely different turbo?
First of all, happy new year every one.
SS1PU is a totally different turbo to the SS1 and I found its a lot better turbo with similar sort of response. Pulls lot harder.
I'm currently evaluation CBB G3, customized turbine housings and few different billet high flow profiles at this stage, will have some results posted soon.
I thought you did away with CBB tech? Many of the good/reliable turbos out run journals anyway, so I dont understand the need for change.
Keep your cost low and reliability high :thumbsup:
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
