Kasko - I got mine done at a 4wd specialist and they quoted $350, asked for $450 and I paid $350 after some arguing.
Stao. Will that little extension work for my turbo with boost drop issues?
Anyone wanna change my clutch so I can join this race :(
Got quoted $500 for the change
I got quoted the same amount (including flywheel machining) and Im on the Central Coast NSW....
that was from a brake and clutch place though...
so I'll do it myself I reckon... its just heavy, everything else is straight forward.
How much power are you running to want to choose from those expensive clutches?
Im running 290rwkw soon to have E85 and jump to about 320rwkw..
Im looking at running Exedy extra extra extra heavy duty clutch $738 abouts...
that clutch will just hold onto 330..
NPC 10' carbotic..about 750$ Simon-s14 uses on his drift car holds 360kw no worries..Few other people have said they are great too..nice soft pedal feel
allthough really if your going to race it you want the flywheel as well (it has a cooling panel to prolong clutch life) which is another 450$..but you could run without it..
thats what im getting anyway.. :thumbsup:
its actually rated alot higher than that, the extra extra HD holds 330, this will hold alot more...
Hamish is abusing it on his 325rwkw ProS setup, been using it a while too...
But I'll look into the NPC clutch too thanks...
Just a note. The excedy heavy duty can't hold 200kw. IN POOR CONDITION
So yeah. If it was new, it was bed in wrong or driven bad and ruined.
200kw is stock clutch territory.
Right now I am tuned to about 240rwkw.
In the future I may chase 260-270 on E85
So just need something that can handle up to 270.
so you could getaway with NSK-7056HHDB for $691
Power Holding Capability (At Flywheel): 499hp / 372kw
Oh ok, there's an extra extra on the extra extra...
I guess Hamish buys clutches like he buys his clothes...:laugh:
Are these street friendly clutches?
Button clutches are normally the ON or OFF type?
Buttons take a lot of effort to drive and maintain IMHO.
The HHHDB (3x heavy duty button) normally gets sticky in traffic and wont like to shift easy or come out of gear. If you know how to use it and stop it from doing that, they are OK.
I would rather have a HHHD which is the 3x hd without the button. It just makes it easier to manage and less stress getting around. It will be forgiving like a normal clutch, where as the buttons dont appreciate driver error. Your passengers will appreciate it even less lol
seems excessive though to spend $1200-2000 on a clutch for the sort of power were talking about here...
any suggestions for better clutches then that dont go over $1K
I use PBR made Clutch Industries RPM kits. They don't exceed the $400 mark too often and have not had one let me down yet.
I havent used one on a 500hp skyline though lol
Ive had exceedy brass button clutch it was ok for around 300rwkws. Other wise try extreme clutch. I had them in my 300zx and sil180, they are good.
    • Physically, you'd expect it to turn the motor 11/8ths faster than a standard one, but I'm not sure of specifics
    • Ironically the GTT was quite reliable in the 7 years of ownership. From memory I've only had to replace a radiator and coilpacks out of inconvenience
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
