Hypergear Turbochargers and High flow Services Development thread
Agree with zebra, but also, it's a cheap copy of a turbo...what did we expect? It's a miracle that the thing even makes the power it does.
In other news, these traction issues I've been having...aren't traction issues. Kind of ashamed I didn't pick up on it earlier, I guess it just didn't have the typical signs of clutch slip because it was happening in all gears and not just the top. It also unsettles the chassis with the clutch losing and gaining grip on/off making it feel a bit like wheelspin. Having a non-functional tacho doesn't help either. Anyway, today I kept my eye on the speedo and the engine got louder but the speedo stayed the same :(
The good news is my tyres are fine, the bad news is that I still have to fork out 500-600 to fix the issue lol. Oh well, I've had good life out of the cushion button...hundreds of launches, DECA after DECA and lots of daily driving. Previous owner installing it was a bonus!
*runs off on a Kasko-esque search without the hundred threads about it* :P
Sucks about your clutch
Question for stao. Where do you turbine wheels come from?
As for reliability look what happened with the bw efr turbos
Manufacturing faults can and will happen
Could it be the diff opening up? I thought I had a slipping clutch, turned out it was the diff really badly one wheeling, would spin first 3 gears in the dry at peak torque.
If it happens in 4th and 5 then year fair call, best way to tell is find a steep hill you can do 100 on and punch it in 4th, it will definitely slip when boost comes on if it is the clutch.
You can pay higher rate and spend more time for errors to not/less likly occur. Which is why all of engineering work are carried out locally under my direct supervision.
The wheels that I'm using are specifically made by a well know foundry to be solid and heat resistant. Which I haven't seen one cracking even thou they are treated in much hasher conditions. Ie internal gated, pump 98 fuel, high boost. But the part does not comes with a cheap price tag.
The TD06 copy, I was told all parts were sourced from Taiwan. I introduced it as a lower cost turbo with intention to generate consumers on a budget, well only countinue if it proven relaible. The price frame on it is impossible to produce the same in Australia.
I don't think the failure resulted with efr is in manufacturing process. To me it is in design and engineering print of the assembly. Means regardless of how well they are manufactured, as long as they were manufactured per print, it will have the weak spot.
Hoo clutch wise I'm using a Twin plate Blitz. It has never sliped. But horrible to drive on road.
Hypergears = clutch killers
Exedy ceramic racing clutch has been doing the job for me for about 18 months now with the various HG's I've had, 24 months including the standard turbo. No problems as of yet. If it ever does fail, I've got the option of either going twin plate or custom carbonetic single plate. Will make the decision if when it happens.
Hahaha Oi shhh you.
Only reason being is I have accumulated all the info you need? ;)
Well we can share info if you find something worth while let me know. I just don't wanna fork out the cash for something im not happy with
Waiting for Tuesday so I can contact NPC and make up my mind
A good guess but unlikely as I have a KAAZ 1.5 way that is pretty recent and the speedo should go up with any wheelspin, but the only time the speedo goes up is when the break in the drivetrain stops, suggesting clutch :(
HHHDB looks like the go, considering my E-flex endeavors of the near future.
That indeed does sound like a clutch then, look into jim berry clutches, he grabs a lot of off the shelf stuff and ups the pressure plate clamp pressure to make some fairly ordinary stuff hold big power without being undrivable, there is a thread here somewhere "need a clutch" or something like that
Can attest to this...I stalled his car about three times! It has two modes: stop and launch lol.
Ok here is a question for all running the 18/20psi actuator. I tested my actuator and it starts opening at 2psi and is open 100% at 28psi. Does this sound about right?
Sorry didn't notice I put 38
Edited by lilcrash
Sorry hit the 3 not the 2. It's open 100% at 28.
Edit - just thought I would add, I tested it on the bench, not in the car.
Edited by lilcrash
NPC clutch on it's way. They reckon their organic is good for 300rwkw...guess we'll find out. Yay for retaining daily drivability!
*sneers at button clutch owners*
    • Hi all, I need to get this HKS SLD attached to my stock ECU because I've now got the German autobahn and faster European circuits to contend with.  The car is a manual 2dr ER34 with an AT ECU and I've realised the AT ECU has two pins for speed sensor signals: Pin 29: Vehicle speed sensor signal (Vehicle speed sensor 2) Pin *58: Output shaft rotation sensor signal (Vehicle speed sensor 1) - *RB25DET A/T model only Before I go butchering this harness, is anyone sure of which pin is the correct one for signal adjustment? The attached document from HKS indicates pin 29 but I found this situation mentioned in the following thread on a different forum (R34 GTT Auto Trans Speed Cut Problem | Zerotohundred) mentioning pin 58 needing to be altered by member zephuros, albeit it seems to be for an RSM-GP and the info appears to be old.  R34_All_Workshop_Manual-pages-2.pdf R34_All_Workshop_Manual-pages-3.pdf R34_All_Workshop_Manual-pages-1.pdf HKS SLD Vehicle Pin out P59-P70 ER34-pages.pdf
    • Embrace the freedom of casual encounters on the best dating app in town! Verified Maidens Superlative Сasual Dating
    • Slimline sub on the rear parcel shelf is doable. Pioneer TS-WX140DA is only 70mm high.
    • People like Johnny Dose Bro might be laughing at my post because I accidentally added 100mm to my numbers. 350-355 is indeed the lower limit. 450 is off-road Skyline spec.
    • What is the "compromise" that you think will happen? Are you thinking that something will get damaged? The only things you have to be concerned about with spherical jointed suspension arms are; Arguments with the constabulary wrt their legality (they are likely to be illegal for road use without an engineering certificatation, and that may not be possible to obtain). A lot more NVH transmitted through to the passengers (which is hardly a concern for those with a preference for good handling, anyway). Greatly increased inspection and maintenance requirements (see above points, both).   It is extremely necessary to ask what car you are talking about. Your discussion on strut tops, for example, would be completely wrong for an R chassis, but be correct for an S chassis. R32s have specific problems that R33/4 do not have. Etc. I have hardened rubber bushes on upper rear control arms and traction rods. Adjustable length so as to be able to set both camber and bump steer. You cannot contemplate doing just the control arms and not the traction arms. And whatever bushing you have in one you should have in the other so that they have similar characteristics. Otherwise you can get increased oddness of behaviour as one bushing flexes and the other doesn't, changing the alignment between them. I have stock lower rear arms with urethane bushes. I may make changes here, these are are driven by the R32's geometry problems, so I won't discuss them here unless it proves necessary. I have spherical joints in the front caster rods. I have experienced absolutely no negatives and only positives from doing so. They are massively better than any other option. I have sphericals in the FUCAs, but this is driven largely by the (again) R32 specific problems with the motion of those arms. I just have to deal with the increased maintenance required. Given how much better the front end behaves with the sphericals in there.....I'd probably be tempted to go away from my preference (which is not to have sphericals on a road car, for 2 of the 3 reasons in the bulleted list above), just to gain those improvements. And so my preference for not using sphericals (in general) on a road car should be obvious. I use them judiciously, though, as required to solve particular problems.
