Being limited by injectors I'm aiming for 230 but have cams and gears so will try and dial it in at the lowest possible rev
I've spent couple of hours on a bridged twin actuator setup with some scraps I had. In theory once both actuators gets connected to a single boost source, the valve open pressure stays the same as having a single actuator, how ever the strength acting against the gate doubles. I hope I'm on the right track and my innovation holding boost steady through out the whole rev range.
Nice work Stao! Thats effectively the same theory as a 'big can' actuator. Hopefully the extra mechanical load works towards holding higher boost levels flat.
FYI to all readers: Payment for my SS1PU has been made! Can't wait to have my new turbo in my hands!
Its different to a big can actuator, I've used it while ago and I couldn't get rid of the boost drop, the current high pressure actuators worked better.
Big can or high pressure actuators will only work to certain extend, the stronger the actuation spring is the more boost spike occurance in mid range as exhaust manifold pressure at that point is not as high as what they are in upper rev range.
The Actuator is acting against both inlet manifold pressure and exhaust manifold pressure, The EBC can bleed off inlet manifold pressure how ever has no control over exhaust manifold pressure. Pressure at any points of its distribution remains constant, So in this setup the advantage of having two actuators halves the force generated through exhaust pressure.
The end result in theory should half the amount of boost drop or better. I've taken the car out for a thrash with both actuators hooked up in one boost source, they are now sitting at 18psi instead of 16psi on a single. So hopefully it holds 20psi flat on the factory exhaust manifold.
And who said you cant reinvent the wheel? ;)
If you get a chance please take some pics when building my turbo, for my personal build log :)
Car going on a local dyno just to compare boost plots with exhaust on and off tomorrow morning
Talked to head company who modified it. They said although squish pads were removed, de shrouding valves should be helping increase velocity and not create any lag and was advised to get an adjustable exhaust gear, dial cams in and see if it picks up earlier plus should be a bit more Det resistant now than before
Also found in another thread someone say they installed poncams and went backwards because head and block were skimmed so 0degrees wasn't really 0. Will bring a dial gauge home from work after my holiday
Edited by t_revz
im also worried about dialing cams im with the decking... Ive decked my block and dropping off my head to be decked today also. Running poncam type R's I hope it doesnt cause headaches..
My squish pads are removed plus other material in chamber yet after being skimmed previously then this time it's back to original CC so I guess it's been skimmed substantially all up, whereas the block only got trimmed 4"thou.
Tuner cringed this morning when I told him valve guides had been done... he said he'll see how the car goes on the dyno and push it as far as he's comfortable, but he said with the motor having been apart, and given its still on the stock exhaust manifold, he thinks it will be between 350-380rwhp.
Shall see how it goes!
LOL please dont tell us it pulls hard again until it is tuned.
last guy to get a HG turbo and see how hard it pulls, pre tune, blew his motor.
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
