The 3540 in 1.06 turbine is a huge turbo for a Rb25det, and he's only 3m/h faster, I think I can get that mileage on 23psi with G3 on MT tyres.
And yes I'm making an 11 blade wheel profile for the SL2 at moment. Aiming at T67's power with 20G's response.
The vid I linked was on a .82a/r housing - he got that mileage on ~20psi on pump gas, so comparing 23psi on E85 is hardly apples and apples. I wasn't trying to compare the GT3582R with your turbo anyway, the GT3582R *IS* a large turbo (on your boost level and E85 it'd push him WELL into the 130mph range) and it is, or at least should be a lot laggier as well.
All I was trying to demonstrate is that an R33 can get into the tens even with a manual if it has the power to trap at 125+mph
Rizz89: Well if we did that high flow on the VL then it will be bit laggy for the Rb25det how ever it should produce more power due to larger wheel profile. Get Plazamaman's cooler kit, proper injectors and a tune.
R33's pretty heavy, is the Skyline in the video been fully stripped for drag? I will ask Trent to lose few pounds or askt Cat to drive for the next drag. :D
Nah I don't think so - though to be honest it was a long time ago so memory is a bit hazy but it was the owner's street car. The head light removal was just a thing done somewhere along the line to see if it made any difference from memory. The car was dynod at 450kw @ hubs as raced - I am sure there is no correction that you could do which would have brought it under 400kw (TCF was 1.00 and no AIT sensor manipulation was done) even though 450kw is a bit optimistic for most fair comparisons sake. It didn't have the strongest power delivery hence not being that quick for the power, it was running only 20psi and it's peak power was at just over 8000rpm and given that it was a stock motor/oil pump/etc he couldn't really rev it much higher to make the most of the peak power and hope to survive a run
Again not sure what the relevance is, I was just talking about trap speeds vs 1/4 mile times.
Hey guys
Good Results this time around at the drags :):):):)
12.807 @ 110.56 mph ( 177.92 kmh )
It was what i think a perfect launch.
hat was with Full 36 psi in my new KU36 tyres.
his shows you hypergears do go hard :):):)
340 HP Fyi
:rofl: so thats why you didn't drive Stao..weight reduction...
guess you haven't met Victor
supernats_wideweb__470x2990_zps863d52d5.
Hey guys
Good Results this time around at the drags :):) :):)
his shows you hypergears do go hard :):) :)
340 HP Fyi
Nice - all looks good to me, nice work!
Congratulations on the time Jay-rod. Good tyres and more practice made a difference. Great work.
Artz: haha yes, having Trent sitting behind steering wheel is like me driving with light weight Porsche wheels with carbon fibra bonnet and boot, plus no interior. He's used to drag VLs with Nos also lot more experienced.
Pretty close to spot on Jay-rod.
340hp at the crank and aprox skyline weight should do 12.2 and 110mph as a theoretical best.
You do have more than that at the fly but this is using a formula to work it out. I think if you were to be doing 112 or so your HP would be spot on for expectations. So your results are good.
Congratulations on the time Jay-rod. Good tyres made a difference. Great work.
Didnt you guys run RSR's? In theory they are slightly better than the KU36?
Yeah I thought Federal RSRs were higher spec than Kumho KU36 too. :S
Either way excellent time Jay-rod - hope that I can get into the 12's my next time out.
I'm running RSRs. They are pretty good on road, probably because I rarely drive it on full throttle. They are not good drags.
Yeah i just mentioned it as i am running them too and at 360kw it grips up pretty hard in 3rd on a street surface so i thought a prepped track would be even better.....
Anyway, Back to the turbos :yes: keep up the good work guys!!!!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
