My car made 324kw with injectors maxed out had faulty coilpacks running 16psi with an ss2 on a mixture of e70.. yet to retune on full e85 with larger injectors and coils
heaps of power for such low boost? first time round I only managed about 310kW with 20 psi. Needed to push it to 24psi to make what I make now and stretch head studs LOL
12074575_958449057532359_191295407393022
Made 280rwkw on P98 with intercooler causing restriction (china 510x250x65) on 17PSI.
Waiting for ethanol content sensor and feature pack nistune to arrive and will couple with a PWR intercooler and go back for e-flex. Pretty damn fast lol. Has 3.70 gears so it's not as stupid as same power with 4.11s but has 100% traction and just hauls lol.
Specs:
- RB25DET NEO: New nissan head gasket, genuine nissan headbolts
- ATR43SS2
- Turbosmart 40mm comp gate off rear housing
- Xspurt 1000CC injectors
- Z32 AFM on factory R31 airbox with lid cut out at rear
- 3" induction pipe
-3" Dump pipe > 4" highflow cat > 3" exhaust with 2 large mufflers
- Nistune ER34 ECU
- 510x250x65 intercooler (china) with 2.5" piping
- Aeromotive 340 fuel pump
Edited by AUSBen31T
  • Like 5
Its been welded onto the standard manifold. If it makes 400 on 20 then il be over the moon but we shall see i havnt got plans to take it back for retune anytime soon unfortunately. Lifes got in the way as it does haha will update when i do though
Just got my injectors from Scotty, tune for my neo with ATR43SS2 ext gate is booked in on 30th with trent, shall post up results.
Any results yet? Keen to see how your external gate ss2 setup went
    • Oof, I don't think you should add it up like that! It sounds much better at $21 per issue. I don't see any problem there if you enjoy the process and the result. I really like the magazine side of it with all the little tidbits and facts. Also, if anything, these forums are all about spending unreasonable amounts of money on hobbys. I wouldn't call it a self-help group because people generally suggest to spend more
    • I put another 2 layers of putty and still getting pinholes. Think i might either try the filler first then putty or just leave the little specs of guidecoat as is and get primer to fill it in. I think i misread understood what you said above when you said my glazing putty wasnt enough for the size of the area. I thought you meant 1 coat and i needed to. But i think what you meant was that I needed filler first? I also went a bit too far out the repair area as my spreader is a bit large.
    • You do sorta. In my instance they were little specs and I didn't even think they'd be pin holes but it all makes sense now. Huge learnings there!
    • Ah ok that makes sense and it's where i think i went wrong because before when i put filler then putty, i didn't have this issue and now i do because i only put 1 coat of putty. Thanks for that heaps man, it's a good way to put it! With my putty I'm using the dolphin glaze which i just saw it says finishing putty lol. I didnt put filler cause it was a shallow area but i see what you're saying. Also I'm an idiot, i just realised that while i put new putty there are pinholes! I probably saw it before and ignored it for whatever reason. I think because i thought putty is used to fill pin holes that itself wont make pinholes but that's incorrect of course. I feel silly now haha. ok I think I know what to do next. Thanks man!
    • Yes correct, the guide coat is showing low spots, in this instance the low spots are pin holes. I agree wetting the areas makes it more visible (but you can see it's there before you wet it as well lol).  Once the panel is flat, the guide coat will be gone
