  • Replies 219
is an adjustable FPR and larger fuel rail necessary? stock fuel pump?
we dont recommend products unless completely necessary.
For around the same price as SARD 700cc injectors we got the rail, injectors and reg for. The injectors we now use are 750cc Siemens items and have 14mm tops and will not fit the STD rail...they wont even fit a Jap aftermarket rail. His Nismo FPR he already had fitted will not bolt to the Hypertune billet fuel rail so the Turbosmart reg was fitted.
So yes the FPR and fuel rail were both required.
He can now sell his almost new Nismo FPR and be well in front...any one interested in purchasing this can PM Bakes. He also has a set of R34 GTR turbo's and STD injectors in excellent condition that he is looking to offload. :)
He has a Nismo fuel pump already installed.
Edited by DiRTgarage
Bakes is the turbo hard piping something you had already or was it considered a neccessary mod? I'm considering something similar for mine. Is it locally made or Jap?
Cheers
HKS piping kit Scoob. Same as i used to run...see Trojan as they bought my old kit...they might sell it to you.
Thanks for the lead Paul. Are they neccessary? Scott would prefer me to get rid of my stockers on the 26/30 as he thinks they might be restirctive, but I've not heard evidence of that for engines below 350rwkw.
Bakes can you please post a pic of the whole turbo side of the engine with the piping installed.
Cheers
Cheers
Ive seen plenty of Racepace street/circuit GTR's with the stock piping...no probelm with 400kw+
Car is tuned and running sweet, however on the dyno we couldnt get it to make over ~240AWKW at 1.2 bar (17PSi)
We worked out that the stock Nissan Cat between my HKS front pipe and rear section must have been restricting way too much air flow.
The cat got KO'd today. The car feels good and the new turbos pull to all the way to red line.
Ill try to take some pictures of the new catch can, etc tomorrow If I get 5 minutes of spare time to firsty clean/wash the car/engine bay.
Will have to head back to the dyno with Guilt Toy some time in the next couple of weeks and see what it pulls now. Might even crank the boost up to 19PSi or so.
so @ what RPM do they hit 1bar in 4th?
why not fit a metalcat?
Dunno mate, will have to check. Will definately have to go back to the dyno. Car should put out >300AWKW with my mods easily at 17-19PSi
Will have to see what effect the cat mod had. If that hasnt helped to free up a bucket load of power, I dont know what the problem could be.
I wouldve thought you could pull 240rwkw with standard turbos and supporting mods, dont know if youve mentioned what power your car was running before this series of mods.
Good luck with the re tune. I have a vested interest in this, was tossing up which turbos as well.
^^ Yeah, I did pull 240 with my standard turbos with stock injectors with just a boost controller.
Car should be making well over 300AWKW now. I cant tell on the street, maybe the problem is somewhere else?? If it is I dont know what??
Have to get back to the dyno and see if the cat has helped free up the power.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
