I am stoaked!! Ran this with a full exhaust.
Cannot wait to get some decent tyres and change the suspension and go back! After this run I drove the car back to Newcastle and it only used a quarter of a tank in 150ks lol
Benm was lookin at my time slips and said "i think this setup now is good for a 11.1"
What a guess mate :P well done. (waits for the its no guess rant lol)
https://www.sau.com.au/forums/topic/262985-guilt-toy-ran-1111-128mph/
  • Replies 42
The setup is good I believe for 10.8's however based on the timeslips you had done last night I said you had an 11.1sec in it which yup you did.
You just need another set of MT's and more practice on launching because your 60's are shocking (but 60's get more difficult with more power and a more complex setup as DirtGarage and 2rismo have discovered).
Forget about removing your cat, won't make any difference if it's a decent enough cat to begin with. Forget about constantly adjusting your tune and boost etc just set it all up to what its capable of and go practice with an identical setup until you crack that 10.
Then you get kicked out due to no rollcage and get to sit around on weekends wondering what use you have for a 380kw skyline :thumbsup:
Using no cat is definately an advantage, i had a high-flow 3" cat (new) and made an extra 20RWKW without the cat.... Looking through the middle of any cat converter it is pretty simple science to figure out they wont flow as good as a bit of hollow pipe.
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
    • Also this is my garage ornament 😁
    • @TurboTapin hey man thank you for all the info! I am about to order my cd00a today for a rb25 neo s15 build I am currently trying to get the ball rolling again on 😁 what is wrong with the Collin’s adapter? Is the bellhousing machining 15mm because that’s how thick the Collin’s adapter is or is that universal across any I decide to go with? Also do you recommend any adapter in particular? Thanks man 😃
