A local circuit guy here in a R32 Gts-t (350rwkw, hollenger seqentual....etc), he got ABS of a VS Commo installed on it, and he recons in 2 race meets it payed for it self in saved tyres (and he's a Dunlop R dealer). Dosn't help that Baskervill is like driving on a off road corse.
Duncan: I've worked on a std R33, R33 V-spec, and R33 V-spec N1, and they are all 3 channel.
ABS has def saved me from flat spotting R comps (R33 GTR) however the GTR systems are not the best even up to the R34 version. Basically once it has activated you have to get right off of the brake pedal to get it to stop rather than just modulate the pedal. I believe more modern ABS systems allow you to modulate the brake pedal to turn it off.
Ben we were looking at 33 but I was sure it was 4 channel, maybe vspec is different? The R32 thing is horribly slow but that is good in a lot of ways, it will never be too obtrusive lol
Michael if the only thing you are missing is the ABS unit they are pretty common, in fact we have 1 or 2 around. But you probably need more like the brake lines as well. You are probably better to just go without unless you are ready for the stuffing around to get it all back in.
Best brakes for street and light track use are standard (maybe new lines and discs, definately with good quality fluid). If you want more than that you would be mad to go past the G4/D2 8 piston calipers and discs.
they are all 3 channel. 32, 33, even 34. same goes for vspecs etc. the only other difference is N1s etc with no abs.
The three channel/four channel thing doesn't make a huge difference.
A three channel ABS system still detects a locked rear in the same way as a 4 channel.
The difference between the two is that a three channel will release (reduce, really) line pressure on BOTH rear brakes. A four channel only does the locked side.
Basically you are trading rear end stability (3 channel) for slightly more retardation (4 channel).
The 34 N1(<-Pic) Marlin and I took in targa last year has I believe a Mitsubishi magna 4 channel ABS system.
I don't know anymore than that though.
Yeah, it had somethin real funky going on..... Everyone tells me that it's impossible to get ABS working in conjunction with twin master cylinders and brake bias, yes that car had it.... DJR... shed any light on that mate?
I believe the bias didn't adjust front/rear as you would expect, but actually diagonally..... why would ya??? lol... rest assured, after we tested it and found it "out of adjustment", with a little moment, we got it right and left it well alone.
I think the theory behind the Magna/Evo ABS pump was it's meant to be quicker reacting.
To be honest I can't think of a reason why you couldn't get ABS to function on a dual master cylinder set up - one with bias adjustment at that. Ofcourse it tends to depend on how you go about the bias adjustment.
If you think about it a reservoir is just a reservoir so that doesn't affect anything.
The twin cylinders are just a different way of proportioning the fluid (ie instead of having springs in the bore of the conventional system)
The bias adjustment just alters the amount of travel each cylinder has relative to your pedal.
The only thing I can think would be a problem is running a pressure limiter for the rears. But if you have a look at the stock set up & the knee points etc even that doesn't appear to be a problem.
So in short it should work. Just don't quote me on that....
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
