  • Replies 269
Posted Images
lol true. will do the next one if i can. by then atleast my brakes will be better then stock.
but ye ill be there will bring mate along for some good pics and also video camera
sweet so if they ask its being run by SAU ye???
and ye ill enter when i have a car worthy to enter lol
Oh come on dude, no excuses. I'll be entering in a stock auto GT-T - we can be GT-T buddies. If you don't drive I'll be dissapointed.
Edit: just had a read. So I'll need a fire extinguisher, secondary bonnet catch and battery triangle - am I missing anything? :P
Anyone? :P
ok so I'm avalible to do this one.
(fly out at 6 am the next morning)
so sandown kinda scares me, not much run off areas.
if I do the DT will I get timings and be in the club championship?
Or so I just need to enter as the slow group and work up the confidence?
either way I'm there
cheers
martin
Anyone? :thumbsup:
yup, you need to have a fire extinguisher mounted properly in the car (not just screwed into the carpet). i made a bracket with mounts to the seat rails in mine. Blue triangle (just blue electrical tape will do fine) to indicate the battery location in the car, and finally the secondary bonnet restraint. if your bonnet on the car is standard it SHOULD be fine as technically it allready has a secondary latch, because you pop the bonnet with the lever, then you release the catch at the front... (mine is standard and ive never had a problem...) also dont forget, cover all limbs, so long sleaves and proper shoes are important. my mate once forgot about this rule and turned up in a short sleave shirt, he had to go home and get changed...
i think that covers everything you need, oh, most important, HAVE FUN!!!!! :down:
cheers
martin
i dont belive there is timing for the DT group.
you could always do the DT this time, get to know the place, then go for timing next time. :down:
its up to you.
Cheers. I've been meaning to get an extinguisher for the '34 for ages, this at least forces me to do so. Can anyone confirm the stock bonnet will pass? Or do I need to go out and buy a leather restraint or similar for it?
Also - the battery triangle - would I be able to use blue Painters Tape instead of duct or electrical tape? It won't hurt my paint and I have that at home.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
