My first session at Sandown ever was in the dry, second session it was pouring rain. Still good fun, you jsut have to be very careful and use higher gears, 3rd when you would use 2nd, 4th when you would use 3rd and be smooth. In a perfect world you would do every track in the wet, for me the next time i have gone somewhere in the dry i have always been quicker. Slow mo in the wet gives you time to really suss the lines
  • Replies 269
Posted Images
It was great for the 6 practice laps I did before coming off :D No rain, just windy and cold.
Thanks to the crew that helped me get the car moving, Martin for his space saver, Mick for his space saver and Escort dude for his jack :)
Pimpin' ain't easy:
what happened juls?
shitty day for me, I only got in 2 timed laps before I retired with oil pressure issues. i got a time of 1:26.2953 which is way off my pb. one day i'll get a good run at Sandown!
It was great for the 6 practice laps I did before coming off :) No rain, just windy and cold.
Thanks to the crew that helped me get the car moving, Martin for his space saver, Mick for his space saver and Escort dude for his jack :banana:
Pimpin' ain't easy:
What happened Juliette? I heard the tyres came off the rim?
Bris. I was there in the arvo and mick and Ryan were going well with the sil80. While packing up all the gear the front rotor cracked spectacularly just sitting there! It was really loud!
Tims 32 went well. Reliability special... well it is a 32 after all!
Datto's go better with tight wheel nuts... :D
I don't envy the 46deg heat even though it's windy and wet here.
I got into a slide at turn 1 I didn't manage to get out of, got airborne over the ripple strip, landed and spun in the grass. The ripple strip and grass at turn 1 told my tyres to leave the rims :D
The shit thing is I managed no more than the practice session before that happened on the first f*cking corner and then the car spent the rest of the day on the infield at turn 2/3.
what happened juls?
I was wondering where you'd gone :) Sorry to hear.
Alot of people had problems today...
Matty, i was wondering where you dissapeared to... i told you this morning its because i keep turning up to the same track days as you, im a bad omen! :P
Juliette, good to see you made it home ok, though it was a shame you had such limited track time today :(
Chris, i hope everything is ok with your engine.
Me, well brakes, aparently you need them... i did one session, lap 4, coming into turn 1, brake pedal hit the floor! (i pooped a little... :D ) just made the turn. came in to find nothing left on the front pads but metal... its my fault, silly me shoulda check this before the day... the things we forget. :)
Sam, what an amazing car! for the minimal mods done, that machine is hoocked up! :banana: and thanks again for taking me round on the passenger session. you steer the car really well! :D
All in all, it was good that the weather held out for us, though there was big tail wind down the main straight for most of the day.
time for me to get some new pads, cant wait for the next track day! :)
cheers,
matty shepo
So Tim was out there. LOL Mick has the life, moving from Dirty2 to that silly thing of Ryans. Did Ryan get into the 22s? He needs to warm and cool brakes properly, he has quite the appetite :banana: LOL and i jsut sold my rotors for a song :)
Matt, sorry to read that again Sandown has been shit all luck for you. So our hopes are with Ryan. If Mick says he prefers Ryan's car to Micks then i am going to have to remove my car from the workshop :P
Oh an Chris? Which Chris had engine problems ?
Oh, and looks like Andrew got his fastest time of the day in the last session. Well done....
Thanks big fella, was going for the 19 but failed again. I forgot how hard this track was on brakes. Mine are in serious need of a bleed.
I didn't have the camera on for the last session as it was just meant to be a bit of fun. I'll put some footage up later on and some data for those that are interested.
Car was flawless again. Keeps amazing me that a 15 year old sh!tter can be this good.
it was an awesome day
no rain except for 1 or 2 drops
i was so wishing i had my car ready for this, but there is always the next one. :)
saw a few ppl with cameras, so would be great to see some action shots :/
Cheers
Well I had a blast today
First proper track day, car went great, even if I was slow as..
have to say 2nd lap of practise hitting the kitty litter at end of turn 1 with a mx5 coming in backwards towards me was a interesting moment had me puckered up when hitting the track again
so destroyed front right tyre, went though 45-50 L of fuel in 97 km, and had the best fun in my own car ever..(no offense to some ex's)
and all this on stree rubber, with very very minimal mods
I strongly suggest anyone that thinking about doing one of these days to bite the bullett and do it!
(oh and see u all at deca)
cheers
M
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
