Hey Guys...
Total newbie here, so pls excuse this dumb question - I wanna fit an aftermarket BOV to my R33 gts-t, so in preparation I blanked off the plumb back hose. This made the engine run very rough, and a fair bit of air hissed from the factory bov outlet on idle. Will this happen when the new bov (GFB basic) is fitted? Was this normal?
Thnx
https://www.sau.com.au/forums/topic/265398-total-newbie-with-bov-query/
Hi there, yes that is normal, the stock blow off valve will leak air when driving off boost causing the engine to run roughly when the air return hose is not connected. they're not designed to vent to atmosphere. My car did the same thing but once you fit a aftermarket one it'll run normal again. I wouldn't recomend driving it with the stock blow off valve running vent to atmosphere either mate.
the aftermarket bov will most probably fit in the place of the factory one.
so until you have that ready to fit, unblock all hoses and leave the factory one on there as it is supposed to.
once you have the new bov, remove the stock one.
block off the big return hose.
attach the new bov and attach the small vacuum line to the new bov.
adjust it as required.
keep the stock bov..
you'll want it back soon
trust me,your car we stall,probably not straight away but it will.
everyone on here told me it would but i ignored them and stalled at an intersection and nearly got wiped out by a truck.
i don't know if this happens to every R-33 GTS-T but i have to get mine tuned for it.
am i right or wrong guys?
that's correct. it might not stall all the time but it will stall and when it does you will look like an idiot at the lights/intersection. an aftermarket MAF based ecu can be tuned to cover up the issue or a MAP based ecu which wont care what sort of bov or if you even have a bov on there.
So true.
Hehe! Yep.
yup, they're right. yet if you manage to boost your car high enough for the stock bov to give in, buy a GTR bov. problem, solved.
True, I know the stock GTR BOV can handle over 300kW if not a bit more with no problems.
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
