  • Replies 64
Posted Images
i was gonna get one last year but chose to get a gtt instead so i could buy a house, which i have done recently, gonna be getting it revalued shortly ( ive spent 40k on it) so it should be worth a fair bit more and then i can use "equity mate" to go out and buy one.
then i will have both lol
congrats on the purchase by the way it look f**king beautiful. hopefully hte recession in japan gets worse so we can all get gtr's and gtreat prices lol
yea nice one buddy. looks in good nik too. I also cant wait till the day I upgrade to a V.spec R34 GTR or even VspecII. Its gonna be either white or Midnight Purple, crouched on some 19' Nismo Deep dish rims. and worked to a realiable 500bhp. and my daily drive will be a Navara ST-X outlaw. :thumbsup:
Hey mate congrats on the buy, looks mint. 34Gtr is the only way to go, "GO ALL THE WAY OR GO HOME", such a big leap from 33gtr's isn't it? I just bought myself a 34gtr too. 500hp is fairly easy to get, thats where i want to get to also. Good luck with it, see ya on the streets. :thumbsup:
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
