Well, i dunno - you're all like 'it did achieve something' without explaining what. Where-as SydneyKid has explained fairly comprehensively in this thread (and others) that the design of the R33/R34 chassis means that a rear strut brace won't improve handling that much - just improve chassis rigidity somewhat - and would be one of the last things you'd do.
So please - and I'm not trying to be nasty here - what improvements/achivements did it give your car in your opinion - and what other suspension modifications has it already got? One of the whole points of this thread (it seemed to me) would be that the OP was trying to determine whether a rear strut brace would be worth it. So your input about what improvements you've noticed (especially in relation to whatever suspension mods you already have) would be useful for them.
Without getting technical (because I'm not an engineer / mechanic), the bar just stabilized the rear through cornering, either at mid-range / high-range speeds. When the back gets loose, it's even more noticeable.
Other suspension changes:
TEIN coilovers
Standard Front Strut Brace
Cusco Rear Strut Brace
Cusco Front Tension Brace
JIC Adjustable Castor Rods
BEE*R Pineapples
HICAS Elimination Bar
TEIN coilovers
BEE*R Pineapples
It's impossible for a rear strut brace on R33/34's to "stabilized the rear through cornering". In R32/33/34's the control arms are attached to the rear subframe not the body, so sticking a strut brace between 2 parts of the body doesn't do a single thing for maintaining the rigidity of the mounting for the upper and lower control arms. So the suspension angles, camber, toe and bump steer benefit nothing from the addition. All it achieves is the linking of the top mounts of the spring and shock units, which in a double wishbone car contributes nothing to maintaining the suspension geometry.
This is especially so in an R33/34's where the parcel shelf support structure already does a good job of linking the strut tops. In R32's, where the strut tops are mounted lower, at the inner guards, and are therefore not joined by the parcel shelf, there is a slightly better argument for a rear strut brace, but even then the effect is miniscule. Unnoticeable by even the most sensitive of drivers.
I should mention that this is not the case with the front strut brace on R32/33/34's, because the front upper control arms are mounted to the body ie; the inner guards. So linking the inner guards adds noticeably to maintaining the rigidity of the mounting for the upper control arms.
Technically what your are feeling with the rear strut brace is placebo effect, you spent the money, you put something on the car that looks good, so it must work and therefore you truly believe that you can feel it. If you don't believe the facts then that's your choice. But if you want to prove to yourself that it's true then a blind test is the only method, have someone remove and replace the rear strut brace without telling you, then you try and pick it. I've done it on an R32 and even a current V8SuperCar driver couldn't get it right more than half the time, mere mortals like you and me have no chance. ;)
Cheers
Gary
  • 1 month later...
dont waste ur time with rear strut brace. (especially the jjr ones they r very shit it actually put my boot out of line lol)
if u want better handling get the following
coilovers
camber
caster
pineappleas
sways (these r the most important i reckon)
awesome tyres
awesome brakes and pads
and if u wanna go the extra step get a cage as well
Damn you SydneyKid! In another thread called "what fits in your boot" or some crap I admitted that I made a custom fibreglass esky to utilise the minimal space of my r33 boot, but then I bought a rear strut brace and it "clashed"
Now I read your bloody logical argument that this was a pointless addition and I'm pissed off.
Well I say, there are some things we don't wanna know. Important things!
Ignorance was bliss. Can't you just talk crap and call everybody thick based on heresay and Wikipedia-sourced info like so many others? Or admit you're trying to sell swaybars as the primary motive behind this?
I need a drink.......
  • 3 years later...
see
Hey GUN_METAL_GTR32,
Did you end up getting this fitted? I have brought one from JJR and it is advertised as "Direct Fit" but when I bolt it up my boot lid wont close I have it the exact orientation as the pic you uploaded... Am I missing something here?
Cheers man
KT
My R34 has the factory fitted rear strut brace and a factory fitted brace between the spare wheel well and the back of the car to stiffen it up , so I don't think it is just for marketing purposes
Now if someone could make these out of titanium, that'd save some weight!
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
