  • Replies 40
what engine and drivetrain it come with from factory. the interior and exterior colour from factory. and any factory fitted options, like a sunroof. Fast is mainly used to get part numbers for you car, enter your vin number -> click on the part you want -> it gives you the right part number for you car.
Anyone who can fast please PM me. . I am curious what it says about an AXIS. . .
Jules
Jules
VIN pls. in you case GH-NM35-000000
being an AXIS when we pop that into FAST it will generate a special screen saying autech version.
I've finally managed to install FAST on my laptop a month or so ago, but have NFI how to use it. I know what kind of info it can provide, but how to access that info is beyond me at this stage... :P
I've finally managed to install FAST on my laptop a month or so ago, but have NFI how to use it. I know what kind of info it can provide, but how to access that info is beyond me at this stage... :(
Just whipped this up. Hope it helps Nick!
Getting started instructions attached.
ReadMe___Important_.doc
Ok.
I like to open up the FAST Menu (as opposed to opening up FAST for Windows)... Don't ask me why though.
Step 1. Select FAST from the menu
Step 2. Put in your VIN (No this is not mine)
FAST will display info of your car
Step 3. Open General Index - this is a way you can find out specific part numbers
Step 4. Select which category the info for the parts your are after are in. For this example I will be pulling up part numbers for NM35 Stamped Stainless Steel Door Sill Trim
*Note* It may take a bit of searching to find exactly what you are after
Step 5. To select a picture, simply left click on it then click "OK". If you have chosen the wrong picture, you MUST right click it to de-select, then select another pic by left clicking.
*Notice the "Page forward" and "Page back" buttons at the bottom of the screen.
And there you have it!
Edited by iamhe77
That isn't all you need to do though iamhe77, just to add to what you have already posted: (in my examples i used my vin but blanked out a bit of it.)
depending on how you have done your part search, via a vin number or just a model code (you can enter just WC34 for example and browse all the parts for the WC34 series stagea). you may have to cycle through the illistrations to get the one displaying the parts you are after.
after you choose the part number on the illistration you have to go back out to the first screen with the cars details displayed. you will see the part you just selected will be listed here. i have picked an alternator/fan belt. to get the full nissan part number you need to click a button up the top, shown in this pic:
after you click that your part number will be displayed
sometimes there will be more than one partnumber for a part, especially when you are searching parts via model code, you will get this screen pop up, all you do is select the part number with the correct year model, engine type/transmission type you are after. it can also pop up if a part has been subceeded with a newer/different part.
another thing that you may be interested in is the factory fitted options for you car
Edited by QWK32
  • 3 weeks later...
Help me!! LOL
I downloaded the 1+gb file and I've just followed all of the instructions in the download and installed a1, a2, a3, b1 & b2 (JDM files?) and followed the setup stuff.
However, when I try to access M35 within FAST it's as if it doesn't exist. I can find WC34's etc but no M35.
Am I missed a pack with th3 M35's or something?
If I enter my VIN it states
"model series can not be found for this vin no
input model or model series"
Anyone know what's wrong?
Help me!! LOL
if you have downloaded it of the web then it is most probably the older version that only covers up to about 2001-2002. this is the version i have and cant see new model stageas and skylines.
i'm not sure if you can download the newer version of fast yet, i know a few people have a copy of it courtesy of Chook.
So I assume that means uninstall, delete everything and start another 1+ gb download?
I thought it would just have been a case of adding another pack with all the details in it :P
Does anyone need a copy of the old one? I can burn to DVD free of chage.
not really. there are a lot of FAST dumps out there- torrent is your friend. I know there is one from 2004ish there. (mine is 2009 JDM,USDM,ADM - I can't copy mine.)
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
