Hey all i dropped my car into my tuners workshop a copy of months ago to get my car tuned back to 7psi of boost because my old EBC had seazed and wasnt holding boost, anway i put a new boost controller into my car and i was hopeing to get a full tune on my car because it was running a little rough and i wanted the boost put back up to a bar. I got a phone call today from my tuner saying bad news piston number 6 has low compression and will need a full rebuild ive been quoted $7 grand how much would you pay for a full rebuild ????
7 grand - that would be forged pistons, tidy up of the head and so on.
If your chasing near stock motor limits (upto say... 250rwkw), i wouldnt go forged at all. Not really worth it.
a stock rebuild would be in the ballpark of ~3.5k - 4k.
Thats if the stock crank is OK to use again.
You really need a set of new stocker/acl replacement style pistons. Use the rods you have, new bearings, head gasket, minor machining and so on etc etc... plus motor in/out as well.
So ye, around 3.5k-4k for a stocker style rebuild it think is accurate enough.
  • 3 weeks later...
Well ive worked out what im doin with my motor. Im gonna rebuild it myself, with help from my mechanic who's had alot of experience in building performance motors. I will be pulling it to bits myself but getting help with putting it back together again! Im looking at doin a full rebuild. Im gonna get a bottom end rebuild kit from horsepowerinabox.com and Ive got a workshop manual. Im just hopeing that machining isnt gonna cost too much! My mechanic has recommended a head tidy up aswell! So work will be started tomorrow ! :P
It's a great learning experience. Make sure you don't follow the instructions too closely in the manual as there are quite a few catches when you don't use Nissan Genuine parts to replace with.
PM DirtGarage or myself if you have any questions that need answering, or put them up here as there are a lot of smart engine builders around here.
I would also recommend calling engineers like Chilton Engineering and ask Dave what he would typically do to an RB engine as far as machining goes. That will give you a good idea on what you should be doing and you can decide how far you want to go from that.
A lot of people will tell you one type of piston or bearing brand is superior to others but at the end of the day, go with the parts that you can get local support for and that are a well known high quality product. There is nothing worse than trying to send back a set of rings or bearings to the other side of the country because they don't measure up right.
Hope this helps.
Hey all im looking at putting a good set of cams into my skyline.people tell me alot of different things and sizes but no1 can really give me any proper answers .what should i put in to my skyline????? its confusing me Its a 97 R33 auto ( auto has been worked up to handle power)im looking at getting a full over haul of the head .ive been told tomiie poncams are great but i wona get good power out of the car with out to much boost .the mods ive done to the car are
CGC highflow
500HP fuel pump
Apexi SAFC 2
Full 3inch
pod
Hks fuel reg
Metal head gasket (to be installed)
forged pistons (to be installed)
Thanks
  • 3 years later...
im looking for a rebuild place to rebuild my RB25 DET engine, been also thinking of doing it my self but need to get engine machined and stuff so dont think it worth it,
i also thought of getting a secondhand engine but who knows it will have same problem. so i thinking just a stock rebuild with standard parts , but want bottom end and head redone and also
all new gaskets , oil pump , water pump and the 100k service done, any recommendations?
CGC highflow
500HP fuel pump
Apexi SAFC 2
Full 3inch
pod
Hks fuel reg
Thanks
Good on ya - do it yourself and learn (and hopefully save a few bucks as well).
Yes Poncams will be fine but you need a proper ecu before you go much further (SAFC won't do)
Check with Nistune but I think you need a particular Z32 ecu and then a Nistune chip for it to make it tunable.
You won't get too much boost from a GCG highflow - you should use whatever it can make - 16-17 psi - why are you afraid of boost?
You'll probably need a Z32 afm some bigger injectors and a FMIC as well.
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
