So i just bought a 2nd hand one. Ill pick it up tonight or this weekend :)
Those of you that have one already, do you have an electronic version of the japanese installation guide? i have the english version but its for US cars, and i think the injector and ignition pins will be different in the ECU.
ill take pics while installing and make an FYI thingo for future people that wish to perform the work themselves
thanks guys!
https://www.sau.com.au/forums/topic/266854-m35-emanage-ultimate/
I will go and pick it up for you if you like? :(
I need all performance advantages I can get :)
If I had have known the little blocked hole on the airbox would have made such a difference to sound I would have done it when I got it lol It sounds different but beefier, performance wise it feels like it achieving better air intake, even with low fuel levels.
Thanks for that :D
thanks guys!
I will have to check when I get home.
I have the CD, but I think it is just has the installation program on it.
For a wiring diagram, check the pdf in the M35 Info thread
thanks mate! i think i have a firmware update for it from the japanese website, but i think ill need the support tool. im guessing this one is just USB not like the blue that needed the dongle to convert that shit to serial.
thats easy, ill need an A to B cable. no need for a pic thanks mate :D
who did your installation of the emanage? the ignition and injectors will be the worst, im guessing ill need to enter the engine bay and check wire colours :)
Not installed yet.
Sitting in my parts cupboard... waiting patiently to be installed.
Haven't decided whether to have eTuner or Status Tuning do it.
Did you get a disc with it? Map sensor?? Universal Harness???
Try emailing Cihan (eTuner). I dare say that he would be willing to help.
Also, check his forum. Lots of info.
Edited by iamhe77
*sigh*
Here I am, trying to be helpful and supplying you with the link to eTuner all the while keeping the post nice and tidy... and you have to go and use Google. :)
On a brighter note, I have been talking with Cihan for some time about the eManage and while he was not overly familiar with the NM35 to begin with (who is?) he has become quite eager to see what the engine can do with the piggyback.
I have asked about a minimum of 200awkw (a "giggly school girl" target of 250awkw) with better fuel efficiency (required) in a RELIABLE tune.
He seems to think that 200 is entirely possible at the least.
Edited by iamhe77
You shouldn't need to lift the bonnet - all connections are normally made at the ecu.
the price isnt too bad for a full tune!
im guessing he is in melbourne?? i might have to find someone in sydney to do it, i know a great tuner, but they only have a 2WD dyno :D
That's INSTALL and tune... I think :)
I do have the support tool. Apparently it is on the installation disc.
Let me know what you need if your does not include software.
Would offer the ol' switch-a-roo... So you send down your eManage, I get it hooked up to my car, tune, send back... but then I remembered that I have a full exhaust and a HiFlow, so not really a tune you would find helpful, I suppose.
Could probably use my mates car as he still has the OE turbo.
He does have Fuji exhuast (OE front pipe & dump) and an ARC intercooler, but that shouldn't make much difference.
Edited by iamhe77
lol youd be surprised what an exhaust and intake can do to a tune!
thanks for the offer but if i was going to that much trouble id just drive there. ill see who CAN tune them here in sydney first before i explore his tuning house.
just need to get this baby wired up :)
Well....if Iain can get me one of those gizmo's too we could always do a roadtrip and come say hello :/
Get the tune's done, I'm all for better fuel economy and any added horsepower (old skool!) would be awesum lol
i found it the silvia nsw forum that i moderate. it was on there for $450 with all 3 looms, the MAP sensor and loom and a loom for a wideband. it was a steal so i got it :)
and i now have it in my hands, well, its in the garage
Cool, I'll be on my way around to collect it in 5 minutes :)
That is a good price, I had a quick squiz on Ebay to see what they were going for. I would have gone down the NisTune road but it appears the M35 computer doesn't like the current versions of the NisTune boards available.
Let us all know how you go with the E-Management Ultimate, sounds like a cost effective solution instead of replacing the whole ecu system.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
