Craig don't you have the Haltech installed? Is it the PS2000?
Had a Haltech Platnum series.....go rid of it a long time ago!
Now have a Nismo piggybacked with and E-Manage Ultimate......I have bugger all low end restrictions with throttle or Cam's......as seen first hand by PN-Mad both in 2WD and 4WD!
Ahh ok...I think the Etuner's site has your car there listed with haltech....that's why I asked
i still cant get over this.. mines still yuck on take off lol..
i wanna see it happen in Video form!
I had the Impul on by itself......I also had just put on the suction pipe and the fabricators had not followed my instructions correctly so I had a slight over boosting problem and as the Impul has no restrictions it helped me to melt a cylinder.
Never had a PS2000 on my car!
Ironpaw where is this Etuners site you speak of....I might have to go and update it a little!huh.gif
.....and if I remember correctly OZ is punching bigger numbers than Japan with the E-manage ultimate with a VQ25det!
You don't remember correctly.
450awps (331awkw) has been done in a street registered NM35 in Japan.
Scott isn't there yet... at least not until the new turbo is installed (if it ever fkn arrives!!).
Having said that, all the "big number" NM35's in Japan have had their capacity increased to over 3L.
Much more impressed with the 2.5L numbers Aus is producing!
I need to find someone stupid enough to sit in the car with me and film:P....where Andy when I need him...lol!....I wont do it again until the shift kit goes in either!.....then I might have to do a quarter run!
Edited by Jetwreck
So with the throttle restrictions; can someone with a stock ecu & an informeter tell me what they get as an output from the "Throttle %" if they flatten the accelerator from a stationary position? Does that corroborate the restriction or is it 'futher' along the line?
Scott's will smash that on E85......shit I recon I'll get to that with a shift kit and 100 Octane and 20PSI and no F-Con Pro!
Take a breath Craig.
That 450awps was on pump... and yes, I know Scott will smash that power level... and yes I know that with the old turbo, his car had very little lag.
Oh, I should mention that particular car wasn't using the Fcon V-Pro... it was using the iS.
I ran a cable throttle and still had the same takeoff, the cams go into full retard below 35? Kph to negate the need for traction control and make the car nice and friendly do drive. I will have the stock cam mapping data soon when I install the Vmanage so I will let you know exactly what it does.
I'm breathing just fine buddy!
Hey did they post up the dyno sheet.....I remember seeing a couple but that was a while ago.......want to compare to Scott's and mine....cannot find in in my J a p browser for some reason!
So what's that advantage of the Fcon units?
Edited by Jetwreck
DO WANT THIS!!!
hurry up!!! before my reno funds dry up!! :ninja:
No dyno sheet unfortunately.
Both F-con's intercept the signal from the ECU to the engine and modify it as per the tune, but they are quite different.
Fcon iS is pretty much an eManage Ultimate + Vmanage, but with a Video output... and it looks pretty (not that you'd see it :P).
That being that it add's/subtracts to the OEM ECU's signals (timing, fuel etc etc).
The problem with this is that the stock ECU is damn clever and will react to the return signal accordingly.
(ie Ecu sends signal to engine, iS intercepts signal and adds a fixed number of degrees to the timing, signal returns from engine to stock ECU, ECU takes additional timing out to bring it in line with what the stock levels "should" be, iS intercepts and adds it's fixed number again - which is now less due to the reduction in timing in the "send" signal from the ECU).
I guess the trick here is to tune outside of the stock ECU's limits :)
Fcon V-Pro intercepts the OEM ECU signal and completely replaces the them with the "tuned" information, so regardless of what the stock ECU receives and adjusts for in the return signal, the V-Pro dictates the parameters in it's "base" tune to the Engine.
Edited by iamhe77
I think it is 79%. If no one else weighs in to say differently l can plug it in & do a test. I do know that I can't get above 87%, ever.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
