scotty nm35 Posted May 25, 2011 Share Posted May 25, 2011 I seem to remember somewhere way back I read (perhaps in the G35 manual) that if the ecu doesn't get the brake signal for a while it goes into throttle limp, not sure but keep it in mind if you do attempt it. Link to comment https://www.sau.com.au/forums/topic/266854-m35-emanage-ultimate/page/22/#findComment-5833089 Share on other sites More sharing options...
Jetwreck Posted May 25, 2011 Share Posted May 25, 2011 (edited) Mmmm..... Boobies!!! My car pulled 5 more psi(so 15psi)by the time in hit 3,000rpm on stall..... Got there a lot quicker too on stall! Launches hard! Well done guys. Edited May 25, 2011 by Jetwreck Link to comment https://www.sau.com.au/forums/topic/266854-m35-emanage-ultimate/page/22/#findComment-5833120 Share on other sites More sharing options...
zei20l Posted May 25, 2011 Author Share Posted May 25, 2011 so use the emanage relay outputs to disconnect the brake line signal till around 50km/h Link to comment https://www.sau.com.au/forums/topic/266854-m35-emanage-ultimate/page/22/#findComment-5833138 Share on other sites More sharing options...
Commsman Posted May 25, 2011 Share Posted May 25, 2011 If you want to try it, its pin 55 on the ecu. Its a pink wire with a blue line.(around the middle of the plug.) Just make sure you tape up both snipped ends well. (Dont hold me responsible if you damage anything please.) lol. Wouldn't dream of it ! I've already lost my ECU harness virginity. No big deal now . I seem to remember somewhere way back I read (perhaps in the G35 manual) that if the ecu doesn't get the brake signal for a while it goes into throttle limp, not sure but keep it in mind if you do attempt it. I was going to run mine via a switch so I could break the connection or return it to normal at any time. Going to label it "Off" and "Fun" lol. That way if there is any issue with the ECU getting suspicious after a while (hey, I just don't brake, OK) it is easy to fix. Throttle limp sucks . Link to comment https://www.sau.com.au/forums/topic/266854-m35-emanage-ultimate/page/22/#findComment-5833146 Share on other sites More sharing options...
scotty nm35 Posted May 25, 2011 Share Posted May 25, 2011 The Emanage doesn't get any speed data as its CAN line data. Even a momentary pulse when you put your foot on the brake would do, only if needed. Link to comment https://www.sau.com.au/forums/topic/266854-m35-emanage-ultimate/page/22/#findComment-5833147 Share on other sites More sharing options...
Commsman Posted May 25, 2011 Share Posted May 25, 2011 (edited) so use the emanage relay outputs to disconnect the brake line signal till around 50km/h The good ideas have been coming thick & fast the last few days. Loving it OK, so some ideas are better than others, but you catch my drift, LOL Edited May 25, 2011 by Commsman Link to comment https://www.sau.com.au/forums/topic/266854-m35-emanage-ultimate/page/22/#findComment-5833154 Share on other sites More sharing options...
andy65b Posted May 25, 2011 Share Posted May 25, 2011 Aaron, to clarify a little on what the Impul ECU is allowing. First, set the Informeter to recognise 100% throttle is 4.12V Now, When I do a launch from a standing start I get around 45% throttle till about 10kph and then I get 100% throttle. On a stall launch, I get around 45% throttle. (But this was not done properly as too much traffic around). But I love this solution... looking for wire cutters on the weekend. Link to comment https://www.sau.com.au/forums/topic/266854-m35-emanage-ultimate/page/22/#findComment-5833166 Share on other sites More sharing options...
scotty nm35 Posted May 25, 2011 Share Posted May 25, 2011 First Andy, try this out. With your foot off the brake for a few seconds, try and launch. Does the throttle go straight to 100%? If it doesn't, unplug the throttle body for a few seconds and try it again. Mine definitely goes full throttle from a standing start without the wiring mod. Then snip snip. Link to comment https://www.sau.com.au/forums/topic/266854-m35-emanage-ultimate/page/22/#findComment-5833186 Share on other sites More sharing options...
Commsman Posted May 25, 2011 Share Posted May 25, 2011 Aaron, to clarify a little on what the Impul ECU is allowing. First, set the Informeter to recognise 100% throttle is 4.12V I've been seeing some references to this figure lately and 2 questions come to mind. 1) I must pull out the manual & find out how to change this setting, and 2) why 4.12V? By my actual voltage measurements on the throttle body & driving around, each 1V equaled 20% opening as displayed on the informeter. That makes sense if its default is 5V equals 100%. If you are saying that the throttle does actually open completely, and this happens at a lower value than 5V (totally believable), then where did this magic 4.12V come from? BTW, the max voltage I read was 4.04V so it's not too different anyway. Link to comment https://www.sau.com.au/forums/topic/266854-m35-emanage-ultimate/page/22/#findComment-5833192 Share on other sites More sharing options...
scotty nm35 Posted May 25, 2011 Share Posted May 25, 2011 Even if it is 86% it wont make any difference to the power output, we have a massive throttle anyway. It may be done on purpose to swirl the air in the plenum. Remember that the minimum voltage wont be 0v either. It is just the range of resistance the TPS gives. Link to comment https://www.sau.com.au/forums/topic/266854-m35-emanage-ultimate/page/22/#findComment-5833198 Share on other sites More sharing options...
scotty nm35 Posted May 25, 2011 Share Posted May 25, 2011 Perhaps someone should put some mesh behind the throttle and shove one of those bullet video cameras in the bov pipe. Link to comment https://www.sau.com.au/forums/topic/266854-m35-emanage-ultimate/page/22/#findComment-5833202 Share on other sites More sharing options...
Commsman Posted May 25, 2011 Share Posted May 25, 2011 Even if it is 86% it wont make any difference to the power output, we have a massive throttle anyway. It may be done on purpose to swirl the air in the plenum. Remember that the minimum voltage wont be 0v either. It is just the range of resistance the TPS gives. Yep, from memory the minimum was about 0.6V at (cold) idle & maybe 0.56V when warm. I think you're right - guess it doesn't really matter if not physically opened 100% if the engine can breath all it needs. However, it would be interesting to see, via a camera, how the theory stacks up to reality. Link to comment https://www.sau.com.au/forums/topic/266854-m35-emanage-ultimate/page/22/#findComment-5833213 Share on other sites More sharing options...
scotty nm35 Posted May 25, 2011 Share Posted May 25, 2011 If you could find a nice clear piece of 3 inch pipe to clamp to the throttle, you may be able to see it. The throttle opens to 100% in neutral and park, also without the wiring mod. (that was the other path I was going to work down if the snip didn't fix it.) Link to comment https://www.sau.com.au/forums/topic/266854-m35-emanage-ultimate/page/22/#findComment-5833221 Share on other sites More sharing options...
scotty nm35 Posted May 25, 2011 Share Posted May 25, 2011 Are you going to be right to twist the wires together if it goes into limp mode tomorrow Craig? Or just restart the car I guess. Let us know how it goes mate. Link to comment https://www.sau.com.au/forums/topic/266854-m35-emanage-ultimate/page/22/#findComment-5833228 Share on other sites More sharing options...
Sunkist Posted May 25, 2011 Share Posted May 25, 2011 i think im off to jaycar tonight to get a switch scotty do you want? i think its safest to have one... Link to comment https://www.sau.com.au/forums/topic/266854-m35-emanage-ultimate/page/22/#findComment-5833367 Share on other sites More sharing options...
Jetwreck Posted May 25, 2011 Share Posted May 25, 2011 Are you going to be right to twist the wires together if it goes into limp mode tomorrow Craig? Or just restart the car I guess. Let us know how it goes mate. no limp mode yet!....what am I the f#$king test mule? Link to comment https://www.sau.com.au/forums/topic/266854-m35-emanage-ultimate/page/22/#findComment-5833398 Share on other sites More sharing options...
Sunkist Posted May 25, 2011 Share Posted May 25, 2011 im not in limp either.. done atleast 80km's since.. Link to comment https://www.sau.com.au/forums/topic/266854-m35-emanage-ultimate/page/22/#findComment-5833401 Share on other sites More sharing options...
scotty nm35 Posted May 25, 2011 Share Posted May 25, 2011 no limp mode yet!....what am I the f#$king test mule? Yup. Don't worry Aaron, I have faith in my dodgy mods. lol. Link to comment https://www.sau.com.au/forums/topic/266854-m35-emanage-ultimate/page/22/#findComment-5833450 Share on other sites More sharing options...
Sunkist Posted May 25, 2011 Share Posted May 25, 2011 Yup. Don't worry Aaron, I have faith in my dodgy mods. lol. oh trust me, if anything was to go wrong, knowing this Stagea, it would've slapped you in the face just as you are about to cut it. Just frustrating it was that simple. lol Link to comment https://www.sau.com.au/forums/topic/266854-m35-emanage-ultimate/page/22/#findComment-5833455 Share on other sites More sharing options...
scotty nm35 Posted May 25, 2011 Share Posted May 25, 2011 What are your thoughts, I guess it makes bugger all difference to your every day driving, unless you want to stall it up right? Link to comment https://www.sau.com.au/forums/topic/266854-m35-emanage-ultimate/page/22/#findComment-5833460 Share on other sites More sharing options...
