Hi
Enquiring on behalf of a friend who is looking at getting some stickers made up for his new business, nothing too flash just a basic logo with company name and number. Something that can be stuck on the outside of car windows and won’t peel or weather easily
Basically after something like the SAU VIC stickers, if someone could recommend a few places and pricing, probably best a place that you have used before or had past experience with, that would be great
Thanks in advance
https://www.sau.com.au/forums/topic/267294-where-to-get-stickers-made/
Not sure if its what your after, nor do I know where to get them, but I have seen an alternative to having stickers on the car. This guy used a large magnet with his company logo on it, meaning when he wanted the car for the weekend he could just take them off, pretty cool if its your car.
Thanks for all the info guys, helps a lot
Tell your mate to send me a PM, I can help him out after I move this week - examples at jdmstyledecals.com but I also do a lot of custom work.
Thanks mate, will have him PM you asap
There's a couple of people out at Caribbean gardens of a Sunday printing stickers up all the time, always busy with people queued up.
I got one done for $5 or $10 and it lasted a good three years on my skyline, went through car washes, high pressure spray at car lovers etc... all good.
email this guy: [email protected]
His names Moe, is in the Sth East Suburbs, just send him a picture file of whateva u want designed and dimensions and he'll hav it on ur doorstep asap...or if ur in his area u can pick it up...gud rates too
Great work, has business but cant remember their name
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
