Hi all, just put some mods on my 1990 32GTR recently with 123ks. So far, I have installed:
  • Vipec ecu running 13psi
  • Blitz pod air filters
  • 3 inch catback exhaust
  • HKS adjustable cam gears
  • sard 700cc injectors
  • bosh 044 fuel pump
  • turbosmart fuel reg
  • nismo fmic
  • vipec boost controller
Everything else stock.
had the car dynoed on shell optimax and it only managed to get 192 awkw. This seems prety low to me with the level of mods i have compared to other owners of GTR's with less mods. Is there something wrong with my motor or is this figure about right? Thanks for your help
https://www.sau.com.au/forums/topic/267688-gtr32-power-level/
There is a whole thread dedicated to RB26 dyno results - a LOT with stock turbos.
Have a look through, you'll soon see what you should be getting with 2-3 pages.
thanks, I looked on the forums, and people are running more power than me with less mods. Maybe the engine is just tired and need a freshen up.
Yeh, my car got 50kw's more in rw mode than in aw mode on the same dyno lol, some dyno's allow for the awkw mode and will read like rw dyno's and some have no correction and will just read the power output at all fours.. Also some will read higher than others because the tuners like them reading that way
That's the shiet thing, some peoples stated awd are actually just adjusted to read like rwd figures, at autosalon for example
I've always wondered about the power loss.. 50kw's seems alot to lose just to the front wheels being on? How can some legitimate tuners get readings on awd dyno's that are only a few kw's different from the same car in rwd on the same dyno
Edited by GTAAAH
I dont understand why you have done what youve done to the fuel system! For standard turbos! You dont need it. Plain and simple.
For the money youve spent on the fuel system you could have bought a second hand set of hi-flows and made ~270kw.
Forget about changing the dumps, thats stupid, might as well change turbos at the same time if youre going to do that.
Yes do a front pipe and check the cat. Or go de-cat. (Best)
P.S 13psi is scary for 19 year old turbos.
+1 and +1.
Standard fuel system is ok for up to ~280kw (tho fuel pumps get tired so it is probably worth replacing that)
I just blow one of my turbos at 13psi. Conservative tune, 120,000kms. (FWIW they're supposed to be replaced every 100,000kms).
ask your tuner about it. what did he say? do a power run in RWD and see if it makes you feel better. and as above, for up to 280rwkw you can use standard injectors, standard reg and standard pump (providing it's healthy).
Yeah thanks for the advice, I'll get the front pipe and cat checked. I guess I should have asked for advice before I started tuning my car. Learning the hard way :P . I bought the GTR off one of my workmates to resell but decided to keep it instead. When he had the car, he upgraded to 3" catback exhaust. was going to change the front pipe and cat, but my mechanic said that they will be fine cause they are aftermarket. He also did Pod filters, VIPEC ECU tuned running 12psi. The car had a power output of 189awkw. So basically I made 3awkw with the added mods :cool: . Better than nothing I guess
I asked my mechanic about the power output, he said that 258awhp aka 192awkws is quite normal for a car running standard turbos. Well thats a bit of the reason why I changed them as well just to be on the safe side cause the system is getting quite old now. nearly 19 years old. But Im not too sure if they have been changed in the past.
+1 and +1.
sorry to hear that your turbo blew. what a bummer. I just hope that my turbos hold up for a little while longer
Im just running the stock turbos. I think Mark was going to run them at 14psi, but decided to run them at 13psi instead
Agreed with Femno's comments, spend money on turbo's and dumps next.
FYI i had 15psi, 262rwkw/236awkw
Car was tuned on same dyno by the way.
Was that on aftermarket turbos?? I have purchased some second hand rebuilt GTR33 steel wheeled ballbearing turbos. Just waiting on them to arrive, Its been 5 weeks and still waiting.
Stockers. Other mods (minimal) are in the thread R31Nismoid linked you to.
Turbos's dont take 5 weeks for delivery from within Australia. Contact the seller, get a tracking number
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
