So for the past month or so I have been considering buying a new daily driver. After weeks and weeks of looking over the internet and through car yards I came to the conclusion that rather than buy a brand new 2 door compact shoe box as a daily driver I would combine a few things that have been in the back of mind, by build myself a car for daily driving that not only is a reasonable size for the day to day traffic but can also be classed as a sleeper.
First step was to find a cheap car with body/engine damage within the price range I had given myself. After sorting through car types on the net considering looks, size, potential and taking in consideration how difficult parts are to get for each type of car I came to the conclusion that an s13 was what I was looking for and seeing as you can pick them up within my budget, parts are cheap, they have a good sized engine bay and can look quite tastefull I decided this was the road to head down and within a week I had found exactly what I was looking for.
1989 Silvia - $1400 CAde automatic.
170,000 km's
Mechanicly the car was in excellent condition but front fenders/bonnet/boot would need replacing. The interior was also in excellent condition upon inpection and I was actually prepared for the interior to be in quite alot worse condition than it was.
1. First step replacing all the panels that need to be replaced
2. sanding the car back ready for a respray
so its been a week since I recieved the car and as of sunday every damage panel will have been replace. I have a bonnet on the way, boot has been replaced as the rust holes were too severe, right panel I recieved today. Door cards have been replaced. Sanding will behind on the weekend.
All to do for the moment is sit at work and think over my engine choice for the car. At the moment its leaning towards a 1uz 4.0L v8. I've been in contact with brindog on nissansilvia.com who has been through the 1uz install on his 180sx and been getting a run down cost wise and what modifications that need to be done to fit the engine.
So thats all for the moment, will be back soon hopefullys with an update.
https://www.sau.com.au/forums/topic/267768-my-project-car-build-up/
That sounds awesome man.
Cant wait to hear how you go with the rest.
Good luck :D
cheers mate.
BN kit is on the way now, bonnet fell through so no bonnet for now lol. Car is completely sanded back ready for spray although im considering filling the creveses in the body where the standard silver pin stripe was. Next week end should see the car preped and primer done, looking atm for how im gana go with a 5 stud conversion, theres almost too many ways to do it these days, prefer not to do too much screwing around. May look at the standard replacement 5 studs hubs, s14 hubs need LCA's and aparently cause more track, also required s13 bearings to be pressed in. Hrm need to have a think over this one... photos will be up next weekend.
On another note, r34 stocko wheels off my 34, had them lying around for god knows how long, may as well use them. May need to stretch some 215/45/17's onto the front though
i thought you were making a sleeper, the bn kit is on of the bigger kits out ther for the s13, definately not a sleeper kit lol
Well, kit or no I seriously doubt many people expect to pull up beside a V8 S13.
Not a subtle choice, but still unexpected.
Yeah, pretty much what I was thinking. If you wanted to make it a sleeper you'd leave it the way it looks now. Cos everybody looks at a s13 and doesn't expect it too perform..... :P
You should have gone supermade 'instant gentleman' for the body kit they arent too aggressive but look schmick ...
Allbeit you don't see many v8 silvias, I can't see a v8 being that good for a daily? Are you planning on throwing a lot of money into this?
:D
good luck its going to be one hell of an expensive project to get it all working right but like the other guys said it wont be any sort of sleeper doing it the way you want to
if it legal do it i did a 1uz into my lexus is200 and never looked back just think it throu and don't buy stuff you don't need like i did and it wont cost that much dellow autootive do a 5 speed conversion for the motor for $2750 rebuilt supra bos and when you buy it ask for the speedo drive it around $88 and put that on first save you finding out the hard way.
Ahh someone else is doing a v8 swap. I bought an s13 shell to do the same thing but ended up going for the ls1 rather than the 1uz. I was considering a 1uz but i could get a cheap ls1 from a friend.
Good luck though. I've been planning my swap for about a year and only just now started to fit parts.
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
    • Correct. The ECU cannot read oil temp. (Well, I think it probably can in some situations. I did have the thought of potentially repinning the ECU when I was doing oil pressure). I am using this into the MPVI dongle, so that the MPVI dongle can read oil temperature. It is attached to a VDO gauge which is obviously calibrated to whatever curve the sender actually is using. This would be easy if I could setup a table of voltage to temperature like many sensors, but it appears I cannot do this and can only setup the transform rule which appears to be Input (voltage) x Multiplier, and add an offset. This to me means it MUST be linear. So it may be a complete waste of time wiring this into the ECU. The idea was that the MPVI3 has standalone logging. I wanted to use this instead of a laptop with serial cable (for wideband) for long datalogs. Given the wideband also has electric interference, I may never trust this either in a world where the serial wideband and the analog output wideband do not agree. Last time I did a trace I could see the two wideband traces follow each other, but one was a little leaner than the other. I plan on playing with voltage offsets and actually driving the thing to see how close they correlate. If they never correlate... then, well, maybe I'll never use either. Ideally I'd like to have the Analog wideband read ever so slightly leaner than the serial one, because the serial one is 'correct'. Tuning the car to be ever so slightly too-rich would be the aim. Not needing to have a laptop flying around in the footwell connected with cables is... an advantage. About the only one from the forced upgrade to MPVI3.
    • Hopefully not, since he knows the fuses work ha ha ha
    • I don't think he's got it on a gauge and on the ECU. I think he's got it on the gauge and on the HPTuners DAq thingo. Remember, we're talking about oil temp here, not something that the ECU is actually interested in for its own sake.
