About to order some bc's for my stag, sick of shitty slammed springs making me bottom out practically every day. I do like a fang but my 180s for that, do you guys recon 12 kg's all round I like what zei said hahah
12kg's are fine for the front.....12kg's are a too hard for the rear imo.....but then again I'm try to get a lot more power to the ground than stock.....I'm running 9.3kg's in the rear atm and it's very snappy in the wet........12's in the rear would be a little bumpy as well.
In between 8-10kg's would be fine in the rear....if you want to play around with it more get a good adjustable rear sway bar.
What springs you got? I wana bottom out.... :(
I'm still trying to research what's the best suspension to use to go low. BC are cheap and go low, but how low? Then there's StanceWorks ZeroClearance coilovers for the 350Z which are built to go low not for performance, but they're a little more pricey.
the BCs can go low. VERY low. check out my display pic, that was the height they came out of the box, looked awesome, but impractical. there was plenty of thread left to go lower, and also higher, which is where i went lol
So what's a practical yet low height (in mm/cm) for our cars?
in your avator pic - is that 10cm off the groung?
nope its more like 8cm off the ground lol
mine is a practical low height where its at now. but the back needs to come down a little, to pull the front bar up slightly as its a tiny bit too low
So how high is it off the ground now?
Where yours sits is where I want mine, possible lower... My chassis will have to grow balls of steel for the speed bumps into my workshop!
HAHahhaahha... I'd really like to see how low your car is going to be and how much damage you are going to do to the underside. :blink:
one braces the bottom rear of the rear subframe. another between the rails just in front of the rear sway bar, and another at the front binding the two black bar things that bolt to the bottom of the front suspension behind the rack.
they all sit higher than the lowest parts of my car - stupid factory mid muffler the size of my house
This one's on SilkRoad's. Top arms hit body, can just fit a match-box between the ground and one of the arms.
I intend to get a new exhaust made up to sit a bit higher, build a sump-guard and modify the rear setup so everything sits a bit higher, so I can drop it lower.
If only there was a sway bar group buy going at the moment... :whistling:
What handling? TBH, on the road the Stagea is always going to be a big wagon... for the moment when I want handling I have the RX7, my Stagea will be my impractical daily driver that shouldn't be a daily driver, until it gets ripped up. :D
lol fair enough!
being that low all your arms are at the wrong angle and having no travel left in the suspension means the ride would be harsh!
anyway, like i said, looks the goods. i still love the pearl white in the M35........ should have bought the RS aero in pearl white that i looked at
Yeh, i'm regretting not taking the time to check out other Stagea's before I got my one.
I had jsut sold my Forester and wanted a new car, and dad(importer) had just bought this one in, took it for a drive, and instantly fell in love. The modern tidy interior, the standard handling, the sound, etc..
If I had of known the turbo one's were so easily available, or the manual ones were out there, I would of tracked one of them down... Now i'm stuck with the poor-spec.. Oh well, it's kind of motivation to do something radical to it, knowing I cant make it any slower than it is now haha
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
